KTuned upgraded also from there last bolt spec to 12.9 grade bolts, which is a complete mismatch regarding torque demand of the bolt and the torque capability of the alu of the block. We discussed this in the KTuned ACPS delete thread. You need to glue the thread and solve a symptom by creating another issue, while bolts still brake. Less often, but still they brake. A better solution is always to understand the load profile of the application and design the bracket accordingly. More to the system load and solution you may find here: K-tuned alternator bolt breaking? | Honda / Acura K20a K24a Engine Forumwhy not just go up to a 12.9 grade bolt while maintaining the normal torque of this bolt. They are way stronger. Bolt breakage commonly occurs if bolt tension is too low letting the bolt experiencing cyclic loads.
I agree. I bought an aftermarket TB. I also bought new OEM IACV, KTuned TPS, OEM map sensor, OEM purge valve. I am sending off the OEM TB to maxbore to bore it to 65mm. incase the 70mm TB fails performance I can swithc it all over to the OEM cable TB.it will work perfectly fine without the water supply. The coolant flow is only a measure to ensure it and the rest of the TB does not freeze up in winter driving conditions. I guess you won’t drive the car in freezing temps anyhow.
The IACV offers perfect cold start, cold idle and warm idle. That is why I don’t see the point in removing it.
this is what I was assuming you would say. Something I found interesting that I took from the owner at Hybrid Racing, we find it hard to expect a customer to pay $500-$600 for a throttle body. That is how much they need to get for them in order to sell them. Just like you just said Lotus, the quality of the OEM unit is hard to pass up. I think Hybrid Racing is the only one who has produced something close to OEM in aftermarket sizing. I would pay $600 for a quality TB.On my former K22 stroker I want from a S90 70mm TB to a J's racing 65mm TB and found no difference in MAP over rpm between the two that was larger than the general fluctuation across a single run. We talk a few mbar here or power differences on the order of <1HP.
Once you see full MAP post 60% TPS you know a TB is too big,
But drivability is SOOO much better with the OEM TB and it never sticks or causes any other issues.
