1 - 14 of 14 Posts
Banned
Thanks to JustinD for the pics, i will add some text later on and more detail pics about the vaccum lines and how to set them up
here are the pics
Nikos, 2 comments.
Not sure what is meant by the "small corner of the idler pulley bracket in order for the linkage to be able to move freely" part. if anything, it may be neccesary to cut another part of the water passage for the linkage, but the idler pulley does not interfere. I will get some more pics/info on the linkage area this weekend when i put the motor in.
And also, as far as what motors this will work on. The k24a2 & k24a4 share this water passage design. But the k24a1 has the different passage like the 2 liter motors and requires the extra cutting. I will get some pics of that too if i can. A buddy of mine has a k24a1 in his EP3.
Wow Nice! Just Put An Electrical Water Pump Wit The Block Off And Have Some More Fun
update please. i need info on wiring it.
Any chance you could post these again? It's not showing up anymore, and I am having a struggle with these things. Thank you!!
1 - 14 of 14 Posts
