1 - 20 of 30 Posts
· Banned
I was talking with TWM induction, and they informed me that the first production run for the k series is out in 54 mm.
Of course, it will not clear any stock hood and by cutting them you are compromissing performance.
I was talking to TWm the other day and they said that the 54mm wouldn't give the best response for the engine and that Skunk 2 was just moving up to a 54mm from the 52mm... I was recommended for the best gains to run the 52's.. So it looks like the 52mm ITB's will be making there way across to my car...
· NOR*CAL
aye bro. dont mean to thread jack but what is your redline in your car?
8800 I know a couple of people that go past that go past that, but personally I think 8800 is about far enough.. From my Knowledge most Hondas handle about 500rpm more than the given redline and still handle being daily driven... I also have a soft limiter in my car at 8600 so it stops any damage happening up the top end... Its mainly there as a shift point...
That's true in most cases, but when you have cams, taking the rpms up to 9k+ helps greatly. :D
· Banned
Goku said:
K2e2vin said:
Goku said:
on the power band, what would ITB give you the most ??
midrange , or top end ??
that would depend on the diameter of the itbs. itb's have better throttle response then
how about for road racing like a short track (similar to streets of willow)
what would be the best size ???
I have to ask what type of "road racing" you will be doing as I am not aware of any series that allows ITBs anyway. Neither Honda Challenge nor the new Honda Cup SCCA series will allow them...
Kedimoto said:
How do the Toda throttle bodies compare to the kit from TWM.
What are the pros and cons of each?
Any realitive info is apreciates as Im in the market for throttle bodies in the near futre.
Price for one…Toda is way to expansive…you can get the TWM almost ½ the price.
The quality Toda is a lot better…
Size Toda is 48mm and TWM is 50 to 54mm…For the K motor it like it big…48mm is not enough…
Sometimes the Twm idle is hi but when you snap the throttle it goes back down…
That is sometimes..
The TWM idle hassle we found to be one of the butterflies doesnt close up enough, if you are keen enough to machine it back you could get it to idle better.. as for the hi idle I think its mainly a problem when they are new as mine doesnt idle hi (have a sticky throttle) as much any more...
But hey when the car is only used for racing it doesnt really matter to much..
1 - 20 of 30 Posts
