1 - 6 of 6 Posts
Hi, all
was searching and looking around for some more detail information on 5 lug set-up
here is what i have 5lug from a CTR
dirty i know :rolleyes:
however i am replacing the 4 lug setup on my EG and upgrading it from the Drums in the rear.
i know the proportion vale from the CTR is different i have seen it . so i know i have to get a 4040 from an Integra ..
My Question, should i use the CTR Hand Break Cables or do I have to use one From an Integra ?
can someone elaborate??
You can use either or and be fine.
If you are changing from rear drums you will also need new parking brake cables (from any Integra) and new brake lines. However if you already have 4 wheel disk brakes, you should be able to use your old brake lines and e brake cables.
That should answer it for you...
1 - 6 of 6 Posts
