1 - 20 of 77 Posts
and im sure 92 octane wont cut it for the 350hp mark. can anyone give me your thoughts.
Being that I know what it takes to build a 350hp NA RACE motor, i would sald say it would be a little hard to do and drive that on the street.
We run e85, which is considered a pump gas, on race motors making that much power. But i dont think you would want to drive something like that on the street.
For example take a look at Nikos's 101.X x 89 build. He is doing that with a decent compression ratio, increased stroke, very good cams and a killer head.
He is shooting for 300 on pump gas. Thats realistic. Making another 50+ hp on top of that is not only going to be very difficult, but hard to keep on pump gas and make it driveable
nitrous will get you there
can this be done? has anyone done it? gimme a good setup as a start for thought?
Can you give a good reason you want a DD 350+ stroked K24? Probably not. Yes it can be done, no it wont be street driven friendly... No you dont even need such a setup on the street. Any 350 all motor K series will be a race motor and nothing for the street. I suggest you do some research and pose a more appropriate street setup and hp goal..
At the least, you can try. If you have E-85 everywhere where you live like we do in CO, you can build the compression to that fuel. Realistically, your going to gauge your compression against the best pump fuel you can get easily out there and build it accordingly. Then what you make is what you make.
Local made 310ish on a BC 2.6 stroker with 12.5:1 CR, drag cartel cams, IPS manifold, ported head.
Its not a daily driver but sees a little street use from what I understand
1 - 20 of 77 Posts
