1 - 20 of 30 Posts
anybody on here have a 3 inch exhuast on a coupe em2. or know if the si will fit thanks
i have a greddy sp2 exhaust on my em2 off an rsx-s. fits perfect. im sure youl have no problem with 3". no different to put a 3" pipe under an rsx than an em2. i dont think an Si exhaust will fit , if you mean 06+. if you mean the hatch , than no it wont.
many have a 3" under their em2.
which SI are you talking about?
Go with any exhaust that is for the RSX-S. Any of those exhaust will fit with very little modification from a muffler shop
thats is the truth.. just dont ecpect to dump it to the ground when u do though
· That SHG guy from Hawai'i
i thought you had to modify the pipes a bit to fit the rsx catbacks?
i just got a skunk2 70 mm exhaust of a rsx will that fit on my em2 with a race header will it bolt right up
please use some puntuation when you type, bc it's so hard to understand what you're asking.
I think you meant: "i just got a skunk2 70mm exhaust off of an rsx. Will the exhaust fit on my em2 w/ a race header? will it bolt right up fine?"
if that's what you meant then, NO it will not bolt up. the rsx exhaust will have to be lengthened in 2 areas. 1 on the mid pipe and another where the muffler is.
RSX exhaust are shorter than the EM2s. If you got the EM2s exhaust then you would of simply just shortened it.
So it will fit somewhat, but will need minor modification from a muffler shop.
If you just bolt it up as is, it will be wayy too short.
how many inches will have to be add in those 2 areas those ?
or should i go with a em2 exhaust
i put an rsx exhaust on my 01 em2 with stock rsx cat pipe and DC shorty header. besides being like 2 inches too short it fits perfect. the tailpipe doesnt quite come out the car far enough , very little. slight modification.
do you think i can use a test pipe or is that to long
Just a heads up if you are considering running a 3 inch exhaust, if you dump your car much you will have no ground clearance. Mine isnt dumped to the wheels and I only have about 2.5 to 3 inches of ground clearance and because of that I have pancaked my exhaust about a foot away from where the downpipe bolts up.
dude. i just mentioned that a few posts up
well i got the shunk2 70mm thats like 2.7 in pipe im going to drop it just not that low
3inch = LOUD!!!!!!!!!!!!!!!
dont expect to sneak up on your cheating girlfriend lmao
NOT TRUE..... to a certain extent of course.. lol... depending on ur setup..
if ur turbo then its quiet... jus add like a resonator or 2...
ALL MOTOR however... u better run for the hills where the cops wont hear it... lol
what part of the exhaust was extended does anybody have pics ?
I have the DC5/EP3 pipe kits if you are interested. I belive that the rsx one is verry close to the EM2.
1 - 20 of 30 Posts
