1 - 20 of 81 Posts
well i finally got tuned the other day and thought id post them up here as well as my build thread
276hp @7500
222tq @5100
k24a4 bottom end
blue print i beams
cp 12.5:1 pistons
type s pump/baffle
steel pan
2004 k20a2 head
2005 k20z1 cams
port matched rbc manifold
stock type s tb
karcepts cold air intake
r-crew header
2.5" magnaflow resonator
3" thermal exhaust
k-pro
tuned by d-rob (derek) at innovative motorworks
(www.innovative-motorworks.com)
i assembled the motor in my spare room/garage and the tune is on Sunoco 93 oct
IK22 plugs
the car
:up::up: WOW
look at that torque curve. I never thought a k24 with stock cams could make it that high.
Good job man!
and good job to d-rob!
damn
great numbers....congrats
i would like to know as well stock sleeves?
that torque at low rpm must feel great its like forced induction numbers.....
very happy for u . ur more then welcome to post the over lay on here if u want to give a cam vs comp test
I never seen a stock head hold the torque like that on a 2.4 - or is it ported?
What would be the corrected hp since it wasn't on a dyno pack
Discussion Starter · #16 ·
what do you mean corrected number? this dynapack is usually pretty damn accurate as far as the hp it measures up against trap speeds ran at the track....
Discussion Starter · #20 ·
ya the pistons that i got off you
for another comparison here is seek167's kme'd tsx motor overlayed on my graph
mine is the solid line
1 - 20 of 81 Posts
