1 - 20 of 22 Posts
Discussion Starter · #15 ·
whats sound deadening material?
motor came with everything except the transmission shifter cable bracket and o2 sensors.
*ecu
*axles
*harness
i also bought the engine in 2004 which might be why it was cheaper.
anyone know what outers to use on the rsx axles for a crx?
crsx said:
i think 1500lbs without the stock engine. as it is today. after the k 2100? minus interior.
it could be less. theres a guy on H-T that got his EF hatch to ~1500-1600lbs with the stock motor. :wow:
fasterthenu, what have you done to your civic to get it that low, just removing interior?
Discussion Starter · #19 ·
wow, thats a nice five lug conversion. how much was it and what is it? nice pure black too. what paint code is that? i take it your civic started at 2096? unless you took of the bumpers or went plexi our cars are roughly the same? i didnt weigh it, just taking a guess. i figured id add a hundred lbs for the bigger engine. what axles did you use?
1 - 20 of 22 Posts
