1 - 1 of 1 Posts
$19000
Please txt me for questions and concerns
717-658-1157
Up for sale is my 2009 Honda Civic si turbo. This is one of the cleanest cars around . It has the full race EFR Borg Warner 7670 turbo kit on it. It just turned over to 50k miles. Has less than 8k miles on turbo setup. I bought the car from the original owner who was from Atlanta Georgia with 40k miles on it. So it goes to show you it is a southern car. All the work was done by origin fabrication based out of Atlanta Georgia. Really a head turning car and very fast. The mod list is very extensive. I've owned the car for 10 months now and I've loved every bit of it. I dailyed the car for 5 months with no problems then bought a cheap civic to keep the miles off this clean car. First I will start with the suspension and work my way through the car.
SUSPENSION
- ksport full coil overs 5k on them. Have camber plates up front
mb battles 17x9 +30 with 245/40 continental DW. Also have new yokohamas to go with it.
- ingrall camber bolts and sliders
- tl type s brembros up front
- stop tech brake pads
-tl type s brake booster
- good ridge stainless steel lines
-Full race traction balls
-ATE super blue fluid
TRANSMISSION
- k20z3 tranny is a Jotech stage 2
- Rsx final drive
- clutch masters fx500 3k miles on it
-Exedy 9lb flywheel
-Hybridracing short shifter
-hybrid racing shifter bushings
-Hybridracing delrin shift knob
-Hybridracing EM1 CMC kit
FUEL / TUNE
- 1200cc donkey power atomizer injectors
- deatschwerks 300 pump
- crushed fpr
- Hondata flash pro
- Tuning done by the one and only D-rob at innovative motor works
ENGINE
-k20z3 block
- type r fd2 pistons
-Rsx prb oil pump
-fresh z3 head with gangster 5 angle valve job
- super tech dual springs
- super tech retainers and seats
-ferrea competition valves
- ferrea bronze valve guides
-ARP head studs
- Borg Warner EFR 7670 .83 a/r IWG
-Borg Warner high boost actuator
- full race t3 ram horn manifold ceramic coated and heat wrapped
- full race 3in vband EFR downpipe ceramic coated and heat wrapped
- full race inter cooler and bumper beam
- full race 2.5" EFR charge piping
- full race 3.5" intake
- origin fabrication true 3in straight pipe full titanium exhaust all vband connections. Worth $1750
- DEI gold foil on everything!!
- DEI fire sleeve on turbo
- Hasport 70a full mounts
Omni 4 bar map sensor
- all p2r thermal intake and throttle gaskets
- NGK 2669 iridium plugs
INTERIOR / exterior
- all JDM type r badges
- excelerate gauge pod
- AEM digital boost and afr gauge
- full race vacuum block
- hybrid racing fuel rail
- Hybridracing oil cap
- hybrid racing fuel pressure gauge
- Hybridracing radiator hoses
- ktuned coil pack cover
- rolled and pulled fenders
- red tail light over lays
- chrome trunk price painted white
- fd2 key fob
- relocated 700CCA battery to the trunk with 0 gauge wire
Could be forgetting a lot of little things also. Like I said this is a one of a kind 4dr civic si that you do not see very often. I've recently put a new water pump, thermostat, alternator, starter, and throttle body on the car. I don't want to see the car go but life goes on and you have to grow up and buy a house at some point. I will entertain all offers but I am hesitant on letting her go. I would like money not interested in any trades. Feel free to shoot me a txt ask me questions about anything. I am located in shippensburg pa 17257. Here is my number 717-658-1157.
1 - 1 of 1 Posts
