1 - 18 of 18 Posts
I got a 07 si with I/H/E and reflash. i want to do some stage 1 cams with no valvetrain needed and no tuning. Is there any cams out there for the z3? and anyone here tried it, thanks for the advance response.
tuning is key to making cams work right and right now there arent alot of options. We have Kpro working on a 07 si along with stage 2 skunk cams and I can tell you the k20z3 will make alot more power with cams and tuning. Our si started out at 178hp stock and we have got it up to 235hp with IHE cams and tuning. There are clips of the car on youtube.
how you make the kpro work?
All the K cams will work just no tuning options available yet!! Waiting on Hondata KPRO!!!:rolleyes:
i'm in the same boat, i have an 07 si and I'm planning to drop in DC5 ITR cams and complete valvetrain. sigh, so this means i'm pretty much going to have to wait? because I don't have the money to simply "swap out my DWB" tranny =/
Dumb question, but, does this mean it's impossible to have this setup tuned to my stock ecu? :(
Thats the way it seems unless you drive to handata and see if they can do a custom reflash if thats possible?
you can run skunk2 stage 1 cams no problem, TSX cams No problem, Hytech sells stage 1 cams, and a special reflash that will work with or without pistons.
the answer is yes.
1 - 18 of 18 Posts
