Hi! So I recently bought my first project, a 2002 Acura rsx type s that needed a clutch/flywheel replacement. The car was running great before just not rolling around too much because of the worn out clutch. The car is currently cranking but doesn’t even seem to try to turn over.
The car was sitting in my garage for a couple of months while I changed the ac belt, spark plugs, clutch/flywheel, and couple suspension parts. After I put it all together the car wouldn’t start!
what I have done after the car was put back together was checking for spark, fuel where I have seen both cases work. Tried to check compression will retry it ASAP.
I have taken off the intake manifold to take out the starter and see if it pops out and spins properly. Fixed a coolant temp sensor that was broken. Now I took of the valve cover and the chain looks good but still confused.
I am completely lost and would appreciate some help 🙏🏼
