1 - 3 of 3 Posts
having problems with the rpm gauge on the gauge cluster, using the hybirdracing 3.5 conversion harness, somewhere in the instructions it says to "remove pin 7 and connect it to pin 14?" don't know which connector it's saying to remove the pin from? is it the factory side harness connector or the conversion harness side(c101). please help, if you have pics that would be awesome. again 2000 integra kswap 3.5 conversion harness no TACH on cluster problem. thanks for your input
1 - 3 of 3 Posts
