1 - 3 of 3 Posts
Ok I just bought a 2006 element with a k24a4 5 speed. The transmission is toast, only has 3&1/2 gears lol. My question is will a 9th gen 6 speed transmission bolt to the a4 and plug in?
I believe the rear mount will be different. It should bolt up to the engine but you'll be missing the mount on the back of the trans to the subframe.
Your exactly right and to make a mount would b difficult. These transmissions are $$$$ so I’m going to attempt my first rebuild with it. I found a 9th gen transmission for 500$ do you know if I can swap internals?
1 - 3 of 3 Posts
