1 - 6 of 6 Posts
Hi guys,
Next month i will put on my 3 inch exhaust but i have a PLM 4-2-1 header with 2.5 inch collector.
Now i was wondering what would be best to do :
-Put in a 2.5 inch to 3 inch conversion pipe
-Or cut of the 2.5 inch collector from the plm header and weld up a 3 inch collector to the header (flex pipe) so that its true 3 inch ?
My setup is:
-EG hatch
-Stock k20a2
-CAI
-RBC
-PLM Tri-y header 4-2-1
-Going 3 inch exhaust now (currently 2.5 inch)
-Kpro
Do you think ill lose HP or TQ when changing to 3 inch collector instead of staying 2.5 inch collector because im running stock k20a2 compression and stock cams ?
The TIG welding will be done by someone who has extreme welding skills he makes motorcycle exhausts for a living ...
Thanks in advance
· trial user
2.5" collectors are the standard for Hi-Flowing headers and are backed up by dyno graphs with repeatable, proven results both by hobbyists and race teams in numerous 2.5 vs. 3.0 collector comparisons.
· duct tape and zip ties
400+whp NA race motors dont even use 3 inch collectors..
rob, are there specific setups you are referring to? Just for clarification, and so it does not lead back to 'on the interwebz sicksilver said. . .'
I've seen many. They don't have 3 inch collectors. If look hard enough you can find a header pic for just about any fast all motor car. Most are side or hood exit now so it's even easier.
1 - 6 of 6 Posts
