1 - 20 of 21 Posts
1992 Civic VX to K20a2 build thread
Not new to Honda game but this will be my first K swap.
Shell: bone stock 92 VX
donor car: 04 Type S complete running car.
Discussion Starter #2
Pulled the swap from the RSX.
Ordered my mounts,Shifter kit, harness adapter, clutch kit,
I'm gonna keep the Stock axles, convert to 36mm.
Will post pictures of the progress.
personnally i'd use the stock rsx shifter to start. After you're all said and done then you can upgrade if you think you need to, if you have money left. Cheers
Discussion Starter #5 (Edited)
[/URL]
[/IMG]
Replacing the stock clutch, Exedy kit, lightened flywheel
Working on fuel lines
Mounted up
Before and after
Header install
Radiator,swivel neck and hoses completed
full 3" exhaust
Hey bro ive got a couple of questions about your swap. Ive got an 04 type s for my eg too & was wondering what all you had to do in yours to make it plug & run? What did you do about the wire harness?
Discussion Starter #7
I'm using a hybrid racing harness to the stock a2 harness.
It's not running yet, but install is easy.
I'd recommend finding a complete parts car if possible, You'll save when using OEM parts.
Discussion Starter #8
Ordered a JDM ITR 36mm 5 lug conversion,should be here soon.
Wiring is all about done, need to tuck under dash.
Hope to have running at least this weekend
Discussion Starter #12
Hello sirtef9, thanks for sharing your built story. How was the drive experience this weekend with it?
I haven't driven it yet, still finishing up some suspension pieces, hope fully in the next 2 weeks.
I got her as a one owner, unmolested but an after market sun roof :thud:
what radiator are you using along with radiator hoses? . Normally people relocate radiator to passengers side on eg. What conversion harness did you go with? Go luck with buid man keep it up.
Every person I see using hybrid racing conversion harness check engine light is on for.multiplexers why is that?
Discussion Starter #17
K tuned radiator and hoses, swivel thermostat housing.
Hybrid racing harness.
It runs great,hauls ass compared to stock. I have a AEM fuel pump to throw in then get it tuned. Fun car for sure.
Very nice most definitely will be a fun car.
Discussion Starter #20
I came across some good deals, needs a few more things then some body love.
1 - 20 of 21 Posts
