So I am buying parts right now and I’m wanting some help to build at least 700-800 whp. I am putting the engine in a sand rail and want it to be crazy money really isn’t an issue but I don’t want to spend an outrageous amount I want to stay around 15000 for the total engine build. I will put my parts list down below and you guys let me know if you would change anything. Everything isn’t final I’ve only bought the thing I know I need so far and I can change things up if needed also if you see anything missing or a good thing to add on I will most definitely buy it if it helps thanks in advanced sorry if this is the wrong place to post.
K24a2 engine
K24a2 head
New crank balanced (old one spun a bearing)
Brand new oem lost motion springs
Skunk2 K series alpha valve springs with titanium retainers
Skunk2 K series steel spring base kit
Honda Rear Crank seal
Manley 24A turbo tuff rods
King thrust bearings
King XP Series rod bearings
King XP Series crank bearings
ARP Head studs
Honda k24 timing chain brand new
K-tuned timing chain tensioner and billet cover
Radium Engineering K series fuel rail
id2000 injectors
4p re built head
Skunk2 retaining pins for valve
Skunk 2 valves
4 piston tool kit
Wiseco pistons k622m88
Humble Performance css and o ring block bored to 88mm
K tuned Stand-alone water pump
Dampener
Oem Timing chain guides and bolts
Skunk2 timing cover
Exhaust studs
Plm exhaust manifold
ball bearing turbo (not sure what brand yet)
Hal tech elite 1500
Engine harness
Comp clutch
02-05 Civic Si trans
Switchboard
Axles
Ported oil pump
Timing chain guides all top and side
K20 lower timing chain guide
K20 lower oil basket
Intake manifold
90 mm throttle body
New length serpentine belt
Engine mounts
Hydro clutch
Like I said I don’t know much of what I need to hold 7-800 whp so please let me know if you see anything off also. The trans will be built.
K24a2 engine
K24a2 head
ARP Head studs
id2000 injectors
4p re built head
Skunk 2 valves
4 piston tool kit
Dampener
Skunk2 timing cover
Exhaust studs
Hal tech elite 1500
Engine harness
Comp clutch
Switchboard
Axles
Ported oil pump
Intake manifold
90 mm throttle body
Engine mounts
Hydro clutch
