81 - 100 of 100 Posts
these drag cartel cams seem like monsters! pity you need the high comp in the k24 to make them work, mines running 11.1comp.. sick setup bro:)..
how high is high? 12.5:1 isn't THAT high if you think about it... they're on 91 pump! you've ran cartel stage 4 on 11.1 comp?
noo 12.5 not high, nope im on 11.1 09 tsx's and want to run cartel stg4's but thinking comp too low.. 12.5 seems ideal on pump fuel and can run these cams for a dd :up:
Quick question regarding your fuel set up, what fuel pressure are you running with 410cc injector? what duty cycle were they at? are they pretty much maxed out?
Im building a set-up that probably around 290-300whp maxed and was considering 750cc injector but if 410cc rdx is capable i would love to use those.
Daily Driven FG2
Owner - John Chavez(jchavez)
Builders - Daniel Butler(palmerblock)<---Engine Builder, Ryan Zamora(0ecko01)
Church Automotive Dynapack - orange(pump gas) teal(race gas - ms109)
MD Automotive Dynojet - all were on pump gas
...fyi, the pumpgas plot on church's dyno and the plots on md automotive's dyno were done within 1 hour of each other on the same day, same calibration, no changes made to accomodate either dyno
Correction - SAE
...this just shows our dyno reads on average 7% higher than a dynojet
Some details below:
-Core - K24a2 (TSX)
-K24a2 block, diamond bore/hone to fit the 87.5mm CP Pistons
-K24a2 crank balanced and polished by Castillo's Crankshaft Specialist
-CP X-Forging 12.5:1 Compression Pistons (Barrier Coating on the dome, Proglide Zylene Anti-Friction Coating on the skirt)
-Crower 4340 Connecting Rods no chinese rods here
-Rotating assembly balanced within 1/4 gram
-ARP Head Stud Kit
-OEM Honda main and rod bearings (spec'd with dial bore guages and micrometers, no plastic guage **** here)
-OEM TSX head gasket
-Hybrid-Racing Fuel Rail
-ATI Crank Damper
-TODA Heavy Duty Timing Chain Tensioner
-Hytech Oil Pan Baffle in K20Z3 oil pan
-RSX Type-S oil pump
-Prototype Racing Oil Pump Spring Mod
-RBC ported/bored intake manifold
-OEM Honda 2010 Acura TL 3.7L DBW TB bored(81mm air intake side to 72mm intake manifold side)
-Portflow Design Head k20z3(09 Civic Si)
-Drag Cartel Stage 4 Cams
-Surpertech springs w/titanium retainers
-Honda RDX 410cc fuel injectors
-Skunk2 Racing Header
-3inch exhaust
-TODA lightweight flywheel, clutch disc, and pressure plate. (The entire assembly is balanced on a dynamic balancer to ensure reliable high rpm operation.)
-Hondata intake manifold gasket
-Hondata Flash Pro with Tuning by Church Automotive (Daniel Butler)
Any Questions?...Any Answers?...
I have some questions regarding my k24z3 engine... can i reach what you have done with my engine and cost wise how much that will cost... ?
Welcome Rayzar to K20a.org.
palmerblock's post is 10 years old. Do you know him?
This was a nice build, lots of time and $ to make it come out right 👍
Yeah, lot's of passion for details like the insulation and friction coated pistons.
Maybe the huge cams would have need a better fitting IM, peaking at 7500 rpm with DC 4.5 cams is way to early. Smaller cams like the DC 3.5 would be a better fit to the used IM, so my assumption. Would be nice to see more of such built long blocks.
Merry Christmas guys 😊
97 civic HX K24a
merry Christmas to you as well , just getting finished up with the family visits for the day 👍
Thanks man! Very good, here it is a 2 day task incl. a trip to my homeland. Yesterday just loaded up my cells in the mountains, looooove it. Hope you guys enjoyed your holidays as well.
97 civic HX K24a
Is the weather pretty nice this time of year where you are ? We also had some unexpected sunshine it was a nice surprise.
No advertising links if they haven't any contribution to the topic.
I'm still debating on swapping in my...links...built K24A1 bottom end into the FG ..
