1 - 4 of 4 Posts
Hey v-tech brothers I'm new here and new too the honda life I traded my cbr1000rr for my new found passion k20 build; but shes got a misfire over iddle above 1,500 rpm. Do you guys know any common trouble areas I can look and figure out this misfire, she has misfires on all cylinders and a random p0300?
Sometimes it can be your valve clearance, maybe you need a valve adjustment, also check your crankshaft position sensor and cam shaft sensors, they can sometimes make your car drive rough. I recently had these codes come up in my car and it was solved by a valve adjustment and a replacement of my crank shaft position sensor, but you should have someone check it, unless you have the knowledge of doing these things.
1 - 4 of 4 Posts
