1 - 8 of 8 Posts
the cables wont fit what i need to make it work i thought it was direct fit? what do i need to buy or modify
Super Moderator
The bracket on the EP3 tranny that houses the cables...
Super Moderator
Buy it and put it on the 6spd tranny
the rsx-s 02-04 is a direct fit. Are you puttin this on a k20a3? Also make sure you have some sort of 6 speed shifter box, whether is be a modded ep3 one or a bcss
oye bori, you need to modify the VSS too. Either that or take the inside from the 06 tranny and put it in the EP one.
1 - 8 of 8 Posts
