1 - 12 of 12 Posts
Well I have a 2008 Si and I was thinking of having 2 ECU's. One Stock and one Flashed with the FlashPro. Just incase I need to take it back to the dealer for something. I dont want to have the Flashed Ecu in the car so it doesnt void out my warranty.
Your stock ecu can be reflashed to stock when you want! The only problem with two ecus is the flash pro still runs the immobilizer function! So the new reflashed ecu may not work due to the immobilizer!
Wait until later this month, Hondata will be releasing their new product and will work with only one ECU. Once you upgrade, you can not go back the the Reflash. There will be some nice options for people with the 06+Si people out there. As well as some cal. files for some engine options.... from what I hear.
Discussion Starter · #9 ·
I know that but all I want to do is have one ECU flashed and tuned and the other one stock. So I can just swap out ECUs whenever I need to.
omg listen closely, you hook up flash pro, you make yourself a kool map. when its time to go back to stock, you flash the ecu back to stock with flash pro, then put your flash pro unit in the closit for a while. then if you want your performance map back, you get flash pro out of the closet, plug it in, and load your kool map again.
easy as that.
wasy as that.
^^^ exactly! Flashpro software should save your last map and you can just put it back when you want! :up: Thats what Kpro does!
1 - 12 of 12 Posts
