Year: 2005 Base Price: Not Available
Make: Acura Production #: Not Available
Model: RSX Type-S Origin: Not Available
Performance:
Top Speed: Not Available 0 - 60 MPH: Not Available
¼ mile: Not Available 0 - 100 MPH: Not Available
Lat. Acceleration: Not Available 60 - 0 Braking: Not Available
Drag Coefficient: Not Available Gas Milelage: City: 23 MPG / Hwy: 31 MPG
Engine:
Body:
Position: Front Engine Drive Wheels: Front Wheel Drive
Configuration: Inline-4 Curb Weight: 2840 LBS / 1288 KG
Valvetrain: DOHC, 4 Valves/Cyl, i-VTEC Weight Dist: 63/ 37
Displacement: 122.1 CI / 2001 CC Length: 172.4 IN / 4378 MM
Power: 210 BHP / 156.6 KW @ 7800 RPM Width: 67.9 IN / 1724 MM
Torque: 143 FT LBS / 194 NM @ 7000 RPM Height: 54.9 IN / 1394 MM
Redline: 8000 RPM Wheelbase: 101.2 IN / 2570 MM
Bore: 3.39 IN / 86 MM Front Track: 58.5 IN / 1486 MM
Stroke: 3.39 IN / 86 MM Rear Track: 58.5 IN / 1486 MM
HP/L: 105 BHP per Liter Ground Clearance: 5.9IN / 150 MM
HP/LB: 13.5 LBS per BHP Steering: Variable, speed sensitive rack-and-pinion power steering
Compression: 11.0:1 Steering Ratio: 14.9:1
Block: Aluminum alloy with cast-in iron liners Turning Circle: 38.1FT / 11.6 M
Cylinder Head: Aluminum alloy with 4 valves-per-cylinder pent-roof combustion chambers Materials: Steel unit body
Ignition: Direct ignition system Front Brakes: Ventilated Discs w/ ABS
Fuel Delivery: Programmed Fuel Injection (PGM-FI) Front Brake Size: 11.8 IN / 300 MM
Induction: Not Available Rear Brakes: Discs w/ ABS
Firing Order: Not Available Rear Brake Size: 10.2 IN / 259 MM
Fuel: Premium Unleaded Front Wheels: 17.0 x 7.0 IN / 43.2 x 17.8 CM
Emissions: LEV-2 (Low Emissions Vehicle-II) emissions control Rear Wheels: 17.0 x 7.0 IN / 43.2 x 17.8 CM
Exhaust: Not Available Front Tires: P215/45R17 Michelin 4 all-season high-performance
Rear Tires: P215/45R17 Michelin 4 all-season high-performance
Front Suspension: Fully independent Control-Link MacPherson strut
Rear Suspension: Fully independent compact double-wishbone with coil springs and stabilizer bar
Transmission:
Type: 6-speed manual 5th Gear Ratio: 0.921:1
CVT Ratio: Not Available 6th Gear Ratio: 0.738:1
1st Gear Ratio: 3.267:1 7th Gear Ratio: Not Available
2nd Gear Ratio: 2.130:1 Reverse Ratio: 3.583:1
3rd Gear Ratio: 1.517:1 2nd Reverse Ratio: Not Available
4th Gear Ratio: 1.147:1 Final Drive Ratio: 4.765:1
Interior:
Seating: 4
Front Headroom: 37.8 IN / 960 MM Rear Headroom: 34.1IN / 866 MM
Front Legroom: 43.1 IN / 1095 MM Rear Legroom: 29.2 IN / 742 MM
Front Hiproom: 51.1 IN / 1298 MM Rear Hiproom: 46.2 IN / 1173 MM
Front Shoulderroom: 52.6 IN / 1336 MM Rear Shoulderroom: 51.3 IN / 1303 MM
Performance:
Engine:
Body:
Transmission:
Interior:
Seating: 4
