1 - 3 of 3 Posts
I am new to this your help will be greatly appreciated. I have a complete 05 ep3 swap and. ecu I want to know the difference between it and a 02-04 base rsx. like the engine harness and ecu. Are they any different ? Also the axles ? thank you
if it's the 5 speed ecu they are the same. but you'll need the key and immobilizer from the base rsx in order to start the car. that's assuming that you don't have kpro. as for the axles, they are the same too.
1 - 3 of 3 Posts
