1 - 3 of 3 Posts
ive got everything done on my swap except the vss i have a 04 k20a2 motor with a 05-06 engine harness and the vss plugs are different so im wondering is there anyway i can switch the wires on my 05-06 harness so i can use the type s vss plug to plug into my type s vss like is there any color combo of the wires on the type s plug and the 05-06 plug To make it work, and plug and play.
heres some picks
TYPE S Vss Plug
http://i1145.photobucket.com/albums/o502/K20savagebeast/1f841afc.jpg
http://i1145.photobucket.com/albums/o502/K20savagebeast/76729627.jpg
05-06 si Vss Plug
http://i1145.photobucket.com/albums/o502/K20savagebeast/edbf10e7.jpg
http://i1145.photobucket.com/albums/o502/K20savagebeast/c01177ea.jpg
PLeaaseee Any helpp would Be Greatlyy Appreciateddd..:coleman:
Cant you just de-pin the plug from the 05-06 harness and re-pin it with the 02-04 plug?
yes you can co the above for the vss plug, but what are you running on the ecu side? you will need to repin the 05 harness to 02 spec. you running 02-04 kpro?
1 - 3 of 3 Posts
