1 - 4 of 4 Posts
I read that some are having issues using 05-06 cables in the karcepts kit . So I installed mine this weekend an this is what i came up with . Looking at the cables from the exhaust outlet of the header. The cable on the left{passenger} you need to trim out the karcepts box this will allow the cable to sit all the way down without the metal peice on the cable hitting . Next side{driver side} on this cable you have a metal sleeve maybe about 2 inches long , look down that sleeve an you will see where the cable actually meets that sleeve . Cut just before that sleeve ends this will allow the other cable to go all the way down . Finishing touch passenger side of the braket that covers the cable exit out the box trim until it fits . This braket will now go on the inside of the box instead of the outside.:up::up:
Did/could you take any pics to help out the visual members? Those Literacy challenged?
1 - 4 of 4 Posts
