1 - 2 of 2 Posts
As the title states, I purchased an 04 TSX with an 04 RSX Type S 6mt. When I bought the car it the trans was not disengaging because the clutch pedal was nearly cracked in half. While trying to diagnose the previous problem, I found that the rear trans mounting bracket had been cut nearly in half. I ordered another bracket and came to the conclusion that it will need to be cut too.The only problem is the TSX bracket will not attach to the transmission at all, just the block.
Is there an OEM bracket that will work? Possibly the RSX? It needs the VSS signal corrected as well so I am exploring those options as well.
There currently is no transmission mounting bracket for the RSX case to mount to the TSX chassis.
It is something you will have to get modified/custom fabrication.
1 - 2 of 2 Posts
