Electric Hydraulic Steering Pump MR2-TOYOTA 2001 - K20A.org .:. The K Series Source . Honda / Acura K20a k24a Engine Forum
Reply
Thread Tools
Old 04-13-2009, 09:54 AM   #1
hondastreet
K20a.org Basic User
hondastreet's Avatar
Default Electric Hydraulic Steering Pump MR2-TOYOTA 2001
DISCLAIMER : I'm not responsible of anything. If you are not mechanically and electrically inclined this conversion may not be for you. I do not consider myself an expert and your results may vary.
I would like to install a 2001 Toyota MR2 electric Hydraulic Steering Pump
Reference link - Aspiration :
http://honda-tech.com/showthread.php?p=38032107
https://k20a.org/forum/showthread.php?t=12251
http://www.evalbum.com/tech/mr2_powersteering.html
http://www.driveev.com/jeepev/convpgs/psteer.php
My car :
All details :
Pump => EHPS MR2 Spyder Toyota 2000 to 2005
250 $
eBay Motors - Autos, Used Cars, Motorcycles, Boats, Trucks, Parts, Accessories, RVs and Other Vehicles
Connection on steering (Integra 94-01)
M14-1.5mm
Connection on pump M16 par 1.5mm
High Pressure hose - 6 AN Each Extremity
Tank you to Karcepts Engineered Solutions - Home
80 $ US
Two Fitting
Russel Brand
RUS-670531 - Russell Fitting, Straight, AN Flare to Metric, Aluminum, -6 AN to 16mm x 1.5 Male - Qty=1
RUS-670521 - Russell Fitting, Straight, AN Flare to Metric, Aluminum, -6 AN to 14mm x 1.5 Male - Qty=1
You need a Bracket to hold in place the MR2 Pump
This bracket is good for all Civic 96-00 with a K20/k24
Pump Bracket
Laser cutting
Installation de la Pompe sur la braket
Paint job 10 $
Rad 65$
Summit Racing - High Performance Car and Truck Parts | 800-230-3030
Quote:
Originally Posted by Karcepts View Post
For the fluid return, you could opt to go with a stock setup, but the cost of the parts just for a mediocre return did not seem to be worth it. I opted to get some 3/8" I.D. hose and utilize a $40 oil cooler from Perma-Cool Industries. P/N: 1007
Rad. installation
Pump installation
Honda Accord 91-93, ABS modul
Diagram
From Honda-tech See my link aspiration
Quote:
Originally Posted by 98SpecR View Post
Electro-Hydraulic Power Steering (EHPS) Conversion
Pump Pin-Out Wiring
See the attached schematics for more details.
Click here for P/S Schematic
Fuse Box Pin-Out Wiring (91-93 Honda Accord ABS)
You won’t need the rest of the lower amp fuses.
Chick here for Fuse Box Schematic
MR2 Diagram:
Oil 6.50$ Cad (2 fois)
Resume - Pricing
Pump : 250$
Hose : 80 $
Fitting : 30 $
Radiateur : 65 $
Huile : 15 $
Bracket : Around 100$
Total : 540 $ and I win 8 HP! lol
Reference:
Russell Performance Plumbing - An Edelbrock Company
Honda | Acura Research, Reviews, Performance Parts, Owners - Honda-Tech.com
Ready to race:
hondastreet is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 05-18-2009, 11:10 AM   #2
hondastreet
K20a.org Basic User
Default Re: Electric Hydraulic Steering Pump MR2-TOYOTA 2001
Up date is done
Old 05-19-2009, 04:40 AM   #3
DB8TypeR
Lifetime Member
DB8TypeR's Avatar
Good stuff!
__________________
Vouches (SOLD TO ): Corsport,9JDMCRX0,ivtec integ, K20A96GsR,JaeDM,11248C,KOOCHYOLOGIST, kmanian,Cay20,masterpiece,RaterR21,_phunh0use,... many more.
Unaffiliated Hustle
Quote:
R.I.P. Brandon aka SmokingAces - "Yes swap that b series out for the slow guy lol n go to the wheel spin mayhem"
DB8TypeR is offline   Reply With Quote Quick reply to this message
Old 05-19-2009, 11:35 AM   #4
blue2000em1
K20a.org Master User
blue2000em1's Avatar
Excellent I'am now going to buy a mr2 pump.who made the bracket for the new mr2 pump karcepts??Also please take more pics of it installed on the ek as I've one and doing the same please.
__________________
Ever wonder why I'am such a fan of BASF Paints??Watch this video.http://www.youtube.com/watch?v=_DE6LulDKzo
blue2000em1 is offline   Reply With Quote Quick reply to this message
Old 05-19-2009, 12:07 PM   #5
hondastreet
K20a.org Basic User
Quote:
I can provide the bracket - just request a price !
I'm gonna take more pictures of the set-up under the sun
Give me one week
Old 05-19-2009, 12:23 PM   #6
mage182
New Member
Thanks for the detailed writeup. I'm impressed. I will def save these details for when it's time to do that aspect of my swap.
mage182 is offline   Reply With Quote Quick reply to this message
Old 05-19-2009, 05:06 PM   #7
98specR
GoldStar
98specR's Avatar
Great write-up hondastreet. However, you didn't have to go far for "Aspiration." Information about this conversion was available to you right here at k20.org.
Check here EHPS Conversion redone
98specR is offline   Reply With Quote Quick reply to this message
Old 06-23-2009, 05:41 PM   #8
rockts
New Member
speed signal is an input or output ?
rockts is offline   Reply With Quote Quick reply to this message
Old 10-27-2009, 04:02 AM   #9
snookwheel
New Member
Resurrecting an old thread... I am doing the MR2 steering pump conversion on my car. I am using it for a Super Stalker that we use for autoX. There is quite a bit of effort involved in turning the 10" wide tires I use.
My alternator is only good for 65 amps (battery is a small optima racing battery), probably enough for the pump. However, as a safety precaution I am thinking of using a large 2fd capacitor much the same as some people do for leveling out voltage drops in high powered car stereo systems.
Any thoughts if doing so would be of value? Would it only help with the initial surge and then only draw additional power recharging? I am trying to level out power surges from fast steering input. Thanks, Scott
snookwheel is offline   Reply With Quote Quick reply to this message
Old 11-06-2009, 05:48 PM   #10
snookwheel
New Member
Edit for above post. Does not seem to need anything to level out voltage drops! Works GREAT! Love it. AutoX next weekend. Thanks for the idea/write-up Hondastreet and F20a.org!
Old 10-07-2010, 09:34 AM   #11
nanman
New Member
Quote:
Originally Posted by hondastreet View Post
Karcepts provide the bracket - just request a price !
Give me one week
Were any more pics of this installation ever taken? I am about to do this installation and I am tying to figure out the best location for the pump?
nanman is offline   Reply With Quote Quick reply to this message
Old 10-11-2010, 11:55 AM   #12
nanman
New Member
Any luck with some pics or ideas of where to locate one of the 2nd gen mr2 pumps in a rhd b series ek civic?
Old 10-16-2010, 07:57 PM   #13
jase
K20a.org Basic User
jase's Avatar
Quote:
you can put it anywhere you want
jase is offline   Reply With Quote Quick reply to this message
Old 03-04-2012, 10:48 PM   #14
BlackNight
New Member
Back from the dead.
I just finished installing this and it will not power on. I am using the Accord fuse box and am getting power to the 50A fuse, but the pump will not turn on.
Any ideas? I wired it up just like the pictures posted.
BlackNight is offline   Reply With Quote Quick reply to this message
Old 01-28-2015, 01:18 AM   #15
Beanz
New Member
Hi Hondastreet,
I'm currently looking to install the same pump into my B18C'd EG, I was wondering if you had a template for the bracket you made up at all? Any help would be much appreciated.
Cheers,
Beanz
Beanz is offline   Reply With Quote Quick reply to this message
Old 01-28-2015, 04:37 AM   #16
hondastreet
K20a.org Basic User
Quote:
Originally Posted by Beanz View Post
Hi Hondastreet,
Cheers,
Beanz
Hello, I can do it for $60 +shipping.
I sold couple of them
2 weeks delevery
Old 01-28-2015, 05:21 AM   #17
Beanz
New Member
2 weeks delevery
That would be excellent, how much would shipping be to the UK?
Old 01-31-2015, 05:04 AM   #18
BOMrsxS
K20a.org Advanced User
BOMrsxS's Avatar
Just out of curiosity, what is the advantage of using this over using the eps from the EP3?
__________________
2006 BOM RSX Type S
IMW built D-Rob tuned K24 264/200
BOMrsxS is offline   Reply With Quote Quick reply to this message
Old 02-03-2015, 09:04 PM   #19
redgsrguy
K20a.org Basic User
redgsrguy's Avatar
2 weeks delevery
I'll take one.
redgsrguy is offline   Reply With Quote Quick reply to this message
Old 02-12-2015, 06:53 PM   #20
kommon_sense
Lifetime Member
kommon_sense's Avatar
Quote:
eps is different ehps. The older civic/integra racks are hydraulic, so you can't use eps without swapping in an entirely new steering rack and the fabrication required to make that happen. With ehps you are just replacing the pump. Ehps works well. I converted my k20 using the older mr2 pump about 6yrs ago and its still going strong.
kommon_sense is offline   Reply With Quote Quick reply to this message
Reply
Bookmarks
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Thread Tools
Posting Rules
You may not post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
