redGSRguy's 1998 Integra Type-R Diary - K20A.org .:. The K Series Source . Honda / Acura K20a k24a Engine Forum
Reply
Thread Tools
Old 07-16-2015, 09:12 AM   #1
redgsrguy
K20a.org Basic User
redgsrguy's Avatar
Default redGSRguy's 1998 Integra Type-R Diary
Best pass [email protected]
Thought it would be fun to put off some work and create a thread for my Integra Type-R.
Will update it as the work day permits! After updating I realize I suck at documenting and keeping track of things.
More random part pics at http://instagram.com/redgsrguy
Huge fan of the JDM front end so when I needed a new car I picked this one up!
Came with the JDM 16s / Zeal Coilovers / Spoon Cams + Cam Gears
Spring on the clutch gave out in the first week so I replaced that along with the stock radiator.
Went with a Fluidyne / ACT clutch + FW also got a Mugen Intake / Samco Intake Arm / Hytech header / Carsound Cat / 2.5" SMSP exhaust kit
Threw it on the local Dyno. Car felt a lot slower since I came from a GSR w/ 4.785 FD and 200 whp /130 tq on the same dyno
Took the car to Thunderhill for a HPDE
https://youtu.be/5LEj9bWUaMY
Drove to LA for an Eibach meet
At the time I threw in a Double DIN head unit / CDT Components / JL 300/4 amp / JL 500/1 amp / JL 7" w7. Eventually took all of it out and sold it
Picked up some Kosei K1s but didn't like the silver and sold them. Briefly ran a VIS CF hood but it was not that much lighter than stock so sold the hood too.
Switched to a painted fiberglass hood that was much lighter. Also got some 16" mag blue CE28Ns
Tried some OEM wheels but didn't like how they sat so far into the wheel well.
Tried some Hyper Blue TE37SLs but didn't like the blue on white.
Ended up going with some Red TE37SLs for a while had to buy some stickers since red sticker on red rim is silly.
Threw in some JDM Recaros to match the wheels but they were not as comfortable as the stock seats for me.
Swapped on some Spoon Twin Block calipers to save some weight and for some bling
Picked up some speed bleeders
I eventually swapped in my old GSR motor with the same Mugen Intake / Hytech Header / 2.5" Exhaust. The setup was fun with the 4.785 gearing but after seeing everyone at the drag strip with a K, I started to piece together a motor.
The bushings on the Zeals gave out and I went with Koni Yellows / Ground Control / Skunkworks Springs
I wanted to get the car running first before upgrading. So pieced together a k20 motor
K20z3 block / k20z1 transmission / Quaife LSD / k20a2 head + Supertech Valve train / Blox Type C cams / ATI dampner / RRC manifold / Blox 70mm TB / Karcepts RRC Adapter plate / K-tuned V2 TPS / BWR swap Header
Took it out to the drag strip with the k20 and managed a 12.4 @ 100? WIll need to find the slip to confirm the mph.
Fly-by Video at the drag strip
https://youtu.be/LgEF_cdyM9A
Made it to the semi-finals and got stomped by a mid 11 second hatch but got to go home with a little bit of cash!
Took the car out to Thunderhill, it was ridiculously hot out there. Picked up a CF scoop to funnel air to the intake.
Vid of one of the sessions out at Thunderhill, the half sized radiator was causing some problems on the hot day.
https://youtu.be/J928E9p_-ik
Picked up a Js racing / First Molding hood to aid with some cooling since I was running a 1/2 size Koyo at the time(Don't recommend this for a tracked car!).
Got this JDM rear hatch for no rear windshield wiper hole but then realized it was too difficult to sell my stock hatch so sold this one.
Had all the parts for electric power steering to go in but after seeing how heavy it was I changed my mind and sold the setup
Did a rainy Thunderhill track even. Got these pics from the old BC Garage guys.
Eventually went bigger w/a k24/k20 setup
k24 block / k20a2 oil pump / 12.5:1 Supertech pistons / Drag Cartel 3.2
The differences between the two motors was night and day!
Picked up a First Molding Lip / Voltex Wing / Spoon Gen 3 mirrors to complete the Carbon Fiber ricer look. Also switched to some higher offset volks since I wanted the wheels to sit in more with wider tires.
Took it to the drag strip and managed a [email protected] Great pics by Joe Nguyen
Quick vid of one of the passes
https://youtu.be/eJ05x8Ix69Q
Laguna Prep, right before drilling some holes for hood pins
Went to some Laguna events with Internet Legend @coolhandluke
Some Video of Laguna Seca
https://youtu.be/rW_zw0PaF7M
Random Pics of Stuff I bought Kingpin Compliance Bearings / Moroso Oil Pan for the k20
Got new Intake setup and tried to do a comprehensive test but failed after realizing how much work it is to swap the spacer on the Skunk2 manifolds.
Swapped the Konis for MCS got a Carbing 3 pt in front and Mugen bar in the rear. P1 splitter for the track.
redgsrguy is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 07-16-2015, 09:19 AM   #2
eddsi
Lifetime Member
eddsi's Avatar
Default Re: redGSRguy's 1998 Integra Type-R Diary
Nice R You going to go K any time soon?
eddsi is offline   Reply With Quote Quick reply to this message
Old 07-16-2015, 09:27 AM   #3
redgsrguy
K20a.org Basic User
redgsrguy's Avatar
Quote:
Thanks, I went K, just haven't found the pics to add to the post yet!
Old 07-16-2015, 11:45 AM   #4
blue89jetta
New Member
blue89jetta's Avatar
Car looks great, nice setup and numbers
__________________
Frank---"DC-2uned" on H-T, "Rollin_a_J" on j32a---Owned: 90 ED6 w/B16, 95 DC4, 90 ED6 w/Built LSV, 08 FG2 and 90 DA6 w/B20B
blue89jetta is offline   Reply With Quote Quick reply to this message
Old 07-17-2015, 09:57 AM   #5
redgsrguy
K20a.org Basic User
redgsrguy's Avatar
Stopped by the local event ATS Funny Night since my friend's shop in in the same plaza. Forgot who took this picture but I send them my thanks.
Thunderhill event with a retired World Challenge Race Car
Wishing I had a white Volk for a 'Murica picture
Super Artsy picture with all the blemishes removed from the car by Joe Nguyen!
Street tires at Laguna
Heard all the EVO guys use these for drag racing so I wanted to try it out too
Booty shot
Lip before I smashed it all over the roads.
Stopping by at Synergy Auto Works in San Jose to see what the guys were up too
Getting to the grid super late for the session with Nathan
Hanging out watching the Miami Heat lose in the finals...I think
Old 07-17-2015, 01:19 PM   #6
ontariorider
New Member
ontariorider's Avatar
awesome ITR and build, keep it up. any future plans?
ontariorider is offline   Reply With Quote Quick reply to this message
Old 07-17-2015, 02:47 PM   #7
redgsrguy
K20a.org Basic User
redgsrguy's Avatar
Quote:
Thanks! One day I will have to go back and clean up the wiring in the engine bay.
I have some canards, tires, s2 ultra 4 cams I need to put on again. Switching clutch cable to one with a 90 degree bend and waiting on a new intake filter to come in since I don't want to deal with cleaning the old one.
Also need to re-install my oil cooler once I find room for it.
I want to wash it but we have a drought in CA and I am lazy.
Old 07-18-2015, 02:02 AM   #8
Smitty_Works
K20a.org Basic User
Smitty_Works's Avatar
very nice indeed sir!!!
__________________
| I | C | B | MOTORSPORT
RECARO seat collector
http://desmondwheels.com/
Smitty_Works is offline   Reply With Quote Quick reply to this message
Old 07-21-2015, 01:35 PM   #9
redgsrguy
K20a.org Basic User
redgsrguy's Avatar
Some pics from my old phone
Picture of the Spoon Calipers
Back when I tried some Bronze TE37s and disliked them.
Another picture from drag racing pulled from Instagram
My friends and I trying to collect all the 15x8 +35 offset TE37s, haha
The time I got a BMX bike to match my car
The time I got a road bike to match my car
Old 08-20-2015, 08:13 AM   #10
KdiZzL3
K20a.org Basic User
Beautiful car
__________________
Itr 00-110
Profunction
KdiZzL3 is offline   Reply With Quote Quick reply to this message
Old 08-20-2015, 10:50 AM   #11
flesh199
K20a.org Advanced User
flesh199's Avatar
nice story man
__________________
Allmotor k25 built not bought
308whp204wtq 94 octane fuel sae corrected
320whp206wtq ftw super 99 fuel sae corrected
flesh199 is offline   Reply With Quote Quick reply to this message
Old 08-20-2015, 11:54 AM   #12
1994RedIntegra
K20a.org Basic User
Great ITR build thread here. Don't know how I missed the beginning but I won't now. Love how you switched thru wheel setups etc until you found what flowed well to you. Keep it up man. Great build.
__________________
Karcepts Engineering FTW//(Great Prices, Products, and Customer Service)// Hybrid-Racing FTW// Corn Fed K20 DC4 Boost Build Thread Coming Soon
1994RedIntegra is offline   Reply With Quote Quick reply to this message
Old 08-20-2015, 01:14 PM   #13
SlowTeggyDC2
K20a.org Basic User
Great build !
What size tires are those you are running ?
__________________
Jesus is coming soon.
King of Kings Lord of Lords
SlowTeggyDC2 is offline   Reply With Quote Quick reply to this message
Old 08-21-2015, 05:58 AM   #14
94ex-vtec
Lifetime Member
I am SO glad you finally started a thread somewhere. I lurk a lot on HT in the ITR and time attack sub forums and see you there. I love the JDM front, hood, and basically everything you've done to make it track ready. Please post up more pics and info when you can. The forums are not dead and are a great place to post up progress and builds.
__________________
My Ultimate ITR Rotrex build thread https://www.k20a.org/forum/showthread...=1#post1669062
K-Tuned http://www.k-tuned.com/blog/
94ex-vtec is offline   Reply With Quote Quick reply to this message
Old 09-01-2015, 04:51 PM   #15
redgsrguy
K20a.org Basic User
redgsrguy's Avatar
Quote:
Originally Posted by KdiZzL3 View Post
Beautiful car
Quote:
Originally Posted by flesh199 View Post
nice story man
Thanks guys!
Quote:
Yea I am finally settled with these +35 wheels, I wish they could be purchased new in orange still. Not a fan of painting/powdercoating but might need to change up the color on day!
Quote:
Originally Posted by SlowTeggyDC2 View Post
Great build !
I have 225/45/15 Bridgestone Rivals on some of the pics and 225/50/15 Toyo R888s in some of the other ones(where it looks like a monster truck).
Quote:
I have been traveling since the beginning of August but will post some updates whenever I get a chance to work on the car!
Old 09-02-2015, 12:43 PM   #16
american.graffiti
K20a.org Basic User
american.graffiti's Avatar
Very tasteful build. Props for building it and driving it!
__________________
Thanks: Will @ Hybrid-Racing | Tim @ Hybrid-Racing | Mike @ K-Tuned | Karcepts
Vouches: Theone4dafans|1320WhtRex|GPWF20C|Mr.KDes|Katman|Go vo82|KseriesFTW|Stern|NAcivicsi
american.graffiti is offline   Reply With Quote Quick reply to this message
Old 09-03-2015, 05:53 AM   #17
BOMrsxS
BOMrsxS's Avatar
Sick car. Any interior shots?
__________________
2006 BOM RSX Type S
IMW built D-Rob tuned K24 264/200
BOMrsxS is offline   Reply With Quote Quick reply to this message
Old 09-05-2015, 04:58 PM   #18
redgsrguy
K20a.org Basic User
redgsrguy's Avatar
Quote:
This it the only one I could find at the moment, tried to keep it simple inside.
Tried a few Recaros with the JDM armrest delete but the stock seats are most comfortable for me for driving around. Too bad they don't hold that great at the track.
Just a Personal Wheel / Mugen Pedals / Hybrid shifter / Spoon rear view and shift knob / JDM door panels and block off
Old 11-06-2015, 10:57 AM   #19
redgsrguy
K20a.org Basic User
redgsrguy's Avatar
Have not done anything meaningful on the car in a while. Washed it and put on a new lip this week. Slowly chipping away at the todo list.
Old 11-06-2015, 12:19 PM   #20
crazyjetsfan22
Recaro Fiend
No idea how i have not seen this on here!? But i love your car such a dope build i have been following you on IG for a while.
Did you notice a large difference when you changed to the spherical compliance bushings? Thats on my list of parts i want just trying to get some real feed back. How are they on the streets ?
__________________
My EK Build thread!
crazyjetsfan22 is offline   Reply With Quote Quick reply to this message
Reply
Bookmarks
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Thread Tools
Posting Rules
You may not post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
