Weak crank. - K20A.org .:. The K Series Source . Honda / Acura K20a k24a Engine Forum
Old 07-08-2019, 11:33 AM   #1
Intra focus
I have a 93 del sol with a K20z3 engine. Running Kpro. Car started fine but I pulled out the harness to tuck it and just clean it up. Now when I go to start it, it cranks super weak like the battery is almost dead but I have tried several good batteries. I will do voltage drop test and starter voltage test just thought I would throw this up for any suggestions. Thank you.
Intra focus is offline   Reply With Quote Quick reply to this message
Old 07-08-2019, 03:46 PM   #2
clumbz
My assumption for the weak cranking I would have to say lack of grounding.. but definitely do all that you have planned on already and cross off as you go. Good luck 🤝 keep us posted
clumbz is offline   Reply With Quote Quick reply to this message
Old 07-08-2019, 06:54 PM   #3
jonnyfrancais
Default Re: Weak crank.
could be the starter slowly dying but its not likely if it ran fine before the wiring cleanup. I'd also say its probably a ground, make sure they are in the correct location and that they contact bare metal on the car
jonnyfrancais is offline   Reply With Quote Quick reply to this message
Old 07-09-2019, 08:42 AM   #4
Intra focus
Thanks guys. Glad to see the forum is alive. Sadly my project has sat since the first start back in 2012. I had a kid and life got in the way but I'm making goof money now and have free time so it's time to finish her up and just wanted to fix a few half ass things I did on the initial build. I took out the entire harness just to check that there were no loose wires or anything. I will put that back in and check all my grounds although I have the wireworx grounding kit and that was not touched as part of the work but I will double check them for sure. I am going to do some voltage test after work this week.
Old 07-11-2019, 08:19 PM   #5
Zedicous
Being an IT guy for decades, when things were running smoothly and something changed, i would go back to the last thing i did and usually find it. Time to play with wires and look for cuts, grounds, etc.
Zedicous is offline   Reply With Quote Quick reply to this message
