Seating Chrome Piston Rings - K20A.org .:. The K Series Source . Honda / Acura K20a k24a Engine Forum
Old 08-15-2019, 04:59 AM   #1
Brotatochip
Default Seating Chrome Piston Rings
Hello everyone.
Got a K24a2/K20a2 I recently put together. While apart I had the cylinders honed and installed some new Mahle pistons rings. Top ring is carbon steel with a chrome facing, oil rings are stainless steel with a chrome facing. Engine has about 250 miles on it so far. Lots of blowby and burns oil after coasting to a stop then taking off again (at least that's the only time I see smoke). Oil consumption is around a quart every 200 miles at the moment. I've run conventional 10W-30 oil, changed it after ~60 miles. After initial startup I burped the coolant system while fluctuating the throttle. Once warmed up I went for a drive and did some 3rd gear pulls then let it coast back down.
First time replacing rings but I have no doubts I installed them correctly. I regret not researching ring material more beforehand. I've read chrome rings can take upwards of 1,500 miles to fully seat, anyone have any first-hand experience with this?
Brotatochip is offline   Reply With Quote Quick reply to this message
Old 08-15-2019, 11:23 AM   #2
Arouse the DAMPFHAMMER!
Default Re: Seating Chrome Piston Rings
Originally Posted by Brotatochip View Post
...First time replacing rings but I have no doubts I installed them correctly. I regret not researching ring material more beforehand. I've read chrome rings can take upwards of 1,500 miles to fully seat, anyone have any first-hand experience with this?
Yeah, this is pretty much what you likely see with hardened ring surfaces. The break in approach to get them sealed is the key to shorten the phase to get acceptable leakdown values. At the former company I was (industrial engine company) we experimented with different coatings and hardening approaches. One could clearly see the effect of the longer duration versus the duration to a sealed piston ring-liner system. It was good to adapt the break in approach to the ring properties. But there were also ring systems, which couldn't adapted to break in process, they were just to resistant for a healthy break in wear.
E.g. if you use chromated rings for NA purpose, I would say, as long as you won't to run it more then 200 kmiles it is overrated to have a chromated ring surface. The break in process, even it is very hard can't challenge the necessary wear of the surface to shape the ring as needed. I wouldn't use chromated rings for an NA application, the radial force to break them in is low and therefore the break in takes long and make the sealing not as good as with an fast break in.
Old 08-15-2019, 11:48 AM   #3
Brotatochip
Really wish I would have researched more on the rings before buying. These were significantly cheaper than Honda rings and I only read good things about Mahle so I went with them.
Does 1,500 miles seem about right to finally seat? Anything I should be doing to help the process? Should I be avoiding idling and constant RPM highway driving?
Appreciate the input.
Old 08-15-2019, 11:58 AM   #4
I am not sure how long it will take to get them seated, this is completely depended on the wear partners, the forces, temperatur, cycles, ... . What you can do is to run mineral oil which has no friction reducers added and run the engine hard. Hard means a lot and long WOT section. It would help to let run the engine against the brakes to calm the vehicle speed. E.g. run it on the highway at 60 mph while having it in 3rd gear at WOT and control vehicle speed by the brake pedal. This put stress to all parts not only to the rings, but to wear the rings more fast it is the easiest way. If you cycle the engine load and engine speed the break in would be better. But this makes driving on the highway more risky for you and others, which I don't recommend to you.
Old 08-16-2019, 03:23 AM   #5
Brotatochip
Thanks Lotus. I've heard about running non-detergent oil which I believe is equivalent to mineral oil. I'll see if I can find some locally.
What I've been doing is going for a ~45 mile drive every day. During this drive I am doing lots of 4th gear pulls up to 6-7k rpms then coasting back down. Trying to keep a lot of pressure on the rings to help them seat. Hopefully in the next couple hundred miles I start seeing some improvement.
Old Yesterday, 01:36 AM   #6
...I've heard about running non-detergent oil which I believe is equivalent to mineral oil...
I am not sure if the detergents affects the wear rate much. The property, which is important, comming with mineral oil, is the lack of friction modifiers like molybdenum or nano-particle based stuff etc.. Keep an eye on that.
...What I've been doing is going for a ~45 mile drive every day. During this drive I am doing lots of 4th gear pulls up to 6-7k rpms then coasting back down...
That is a very good approach. If you play with the car brake to keep WOT while driving within the speed limits, you will see much more duration in higher pressure condition (= higher wear of rings and liners). Just keep an eye on the backside followers of your car, not if they think what is this guy doing here...and call the race control guys .
