Charge pipe size - K20A.org .:. The K Series Source . Honda / Acura K20a k24a Engine Forum
Old 10-04-2019, 09:46 PM   #1
Otown03
Default Charge pipe size
What size charge pipe should I use with the rotrex c38 supercharger from kraftwerks? 2.5 or 3 inch .Im running K20a dc5 motor.
Otown03 is offline   Reply With Quote Quick reply to this message
Old 10-04-2019, 11:26 PM   #2
Lotus
Default Re: Charge pipe size
as the C38 series outlet outer diameter is only 63 mm and in ID is 53 mm 2.5 is all it takes.
Lotus is offline   Reply With Quote Quick reply to this message
Old 10-09-2019, 03:27 PM   #3
mhendel05
Larger diameter = lower velocity. Bigger is not always better or you will lose boost pressure. 2.5” is sufficient unless you are going to serious sfwd power levels.
mhendel05 is offline   Reply With Quote Quick reply to this message
