Making the K hold torque to 8krpm... - Page 2 - K20A.org .:. The K Series Source . Honda / Acura K20a k24a Engine Forum
Reply
Thread Tools
Old 07-12-2008, 06:57 AM   #21
chunky`
Lifetime Member
chunky`'s Avatar
Default Re: Making the K hold torque to 8krpm...
Quote:
Originally Posted by signalpuke View Post
Hondata has the dyno plots in their training videos. http://www.hondata.com/techk-protraining.html
Video 9 has an overlay of dyno pulls from each cam angle 0-50. It shows you that even at 6000rpm, VTC is at work, optimizing torque. At 6000rpm, the graphs show 50deg VTC is 5lb-ft higher than 30deg. When you start higher, you appear to fall further.
Overlay some B-series and K-series dyno plots that are from 2.0L builds and you'll get an even clearer picture of how VTC raising up the midrange is affecting your perceptions of top end power falloff. A 2.0L K-series will have no trouble keeping up with a 2.0L B-series on top end, but will destroy it in midrange so long as VTC is being utilized.
__________________
Twisted Loop Racing
Always Outnumbered Never Outgunned
chunky` is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 07-12-2008, 08:18 AM   #22
nikos
K20a.org Master User
Here's HIGH CAM COMPOSITE
Here's LOW CAM COMPOSITE
OVERALL CAM COMPOSITE
VTEC Composite Crossover
nikos is offline   Reply With Quote Quick reply to this message
Old 07-12-2008, 05:12 PM   #23
JDM96SpecCTR
JDM96SpecCTR's Avatar
Quote:
this is what chunky is talking about... the 40 deg curve loses about 26 ft/lbs from 6k to 7.5k, while the 10 degree curve only loses about 12 ft/lb over that same range.. but thats because at 40degrees it was making 16 ft/lbs more than at 10 degrees.. now imagine that 10 deg. curve as a B series curve, since it cant benefit from the midrange gains that VTC give
__________________
TEAM EXiT
Midnight Auto
EvaUnit01: nope, the american dream is a fully finished car with a K24/k20 setup.
JDM96SpecCTR is offline   Reply With Quote Quick reply to this message
Old 07-12-2008, 08:32 PM   #24
zerotraction
Rebuilding phase
zerotraction's Avatar
Listen to chunky. The midrange is what really seperates the k motors from everything else.
__________________
RIP Adam West
RIP Nick Haines
zerotraction is offline   Reply With Quote Quick reply to this message
Old 07-14-2008, 05:04 AM   #25
jon v
Lifetime Member
jon v's Avatar
I don't understand what you are saying? These motors make as much tq at 3-3500 as they do at 8-8500, and like you said there is not B series going to be making these kinds of torque numbers? I haven't seen a perfectly flat torque band on any NA motor... It has to peak somewhere, and I thin the middle of the powerband is the optimal place for it to peak...
__________________
Quote:
Originally Posted by Mr.E.G.
think about what you are saying here. educated people are saying that some portions of this safety device are in direct conflict with this little thing called physics and you are willing to ignore that simply because of the cage builders reputation? that sounds like religion to me. welcome to the church of fanboyology.
jon v is offline   Reply With Quote Quick reply to this message
Old 07-14-2008, 08:05 AM   #26
EvaUnit01
K20a.org Advanced User
EvaUnit01's Avatar
Of course, because that is where most cars stay at. The midrange. And i do use the term MOST loosely.
__________________
Fear of the blood tends to create fear for the flesh - Silent Hill.
EvaUnit01 is offline   Reply With Quote Quick reply to this message
Old 07-14-2008, 08:40 AM   #27
unsivil_audio
K20a.org Basic User
Quote:
Optimal for daily driving maybe, not for racing. You stay in the upper 2500rpms when your racing with a nicely geared transmission; so you want torque in that area to be as flat as possible. This just isn't the case with the K-series unfortunately; (unless you have a stupid low redline like 6500 or 6k). I'm just one who likes to rev. You have to think of it like this, for every 10wtrq more you can hold till 8k, its 20 more whp.
__________________
2008 - Year of the K.
unsivil_audio is offline   Reply With Quote Quick reply to this message
Old 07-14-2008, 09:45 AM   #28
TheMidasTouch
K20a.org Basic User
TheMidasTouch's Avatar
Quote:
I think i understand the disconnect now. But what your asking for, your getting, you just don't know it(which is good cause its like finding a $20 in your couch .)
Look at the "Before" line on my stock 24A2 before I started tuning. Its Torque curve keeps relatively the same numbers all the way to redline(minus the fuel dips and bumps). Very much like our H and B series brethren. Referencing the 'After' curve now, the very reason torque falls off as hard towards the end, is because it is making so much more torque in the mid/mid-high end of the curve.
However, when you compare the final tune to some B-series examples, this is what it looks like. Keep in mind a K20A/A2 will make similar hp numbers but shift the torque curve down and to the right a grand or so (which just moves the HP curve straight to the right). The B-series for comparison are a bone stock JDM B18-R(blue) and a semi built Ls-Vtec(green). The point really is, at higher RPM's, the K absolutely does make much more torque then B's. It just makes a monstrous amount more in the mid range.
As a side note we later made 201whp with the bolt on type r, no cams just IHE. Nice little motor
Last edited by TheMidasTouch; 07-14-2008 at 09:48 AM.. Reason: I'm editing cause i'm a dummy :)
TheMidasTouch is offline   Reply With Quote Quick reply to this message
Old 07-14-2008, 10:26 AM   #29
jon v
Lifetime Member
jon v's Avatar
You are obviously talking drag racing?
It sounds like you want the torque of the bigger 2.4L motor in the power band of the smaller stroke 2L... the bigger the stroke the earlier the torque kicks in in the power band no?
__________________
Old 07-14-2008, 10:35 AM   #30
unsivil_audio
K20a.org Basic User
I'm just talking optimum performance in general. I mean, the way I look at it, its 2.4l, its gone make some good midrange torque anyways due to displacement.
Yeah the more I look at it, the more I just think its a result of more stroke. I would think it there would be a way to compansate for it however, with cams and/or head porting.
__________________
Old 07-14-2008, 10:39 AM   #31
chunky`
Lifetime Member
chunky`'s Avatar
Not true. You don't want it to be as "flat" as possible. You want the torque to be maximized as much as possible. A k-series is going to make the same or better power up top as a b-series of the same displacement.
TheMidasTouch posted a nice graph displaying how the appearance of a flat torque band can be deceiving.
__________________
Twisted Loop Racing
Old 07-14-2008, 10:41 AM   #32
chunky`
Lifetime Member
chunky`'s Avatar
If you looked at one of the graphs that Nikos posted, there is a built k24 that revs to 10k while holding torque. It's all in the combination. It's not something you can just slap together, but it is possible. Think about it, almost 400hp at 9000rpm. It's ridiculous. I never dreamed that would be possible when I started tuning n/a hondas over a decade ago.
__________________
Twisted Loop Racing
Old 07-14-2008, 10:41 AM   #33
unsivil_audio
K20a.org Basic User
^---lol are you serious, is that what you call holding torque? Continuing to make horsepower is not holding torque.
Yes however, I have yet to see a K-series with a rising torque curve in the upper 2500rpm, so thats why I didnt say it.
__________________
Old 07-14-2008, 10:44 AM   #34
chunky`
Lifetime Member
chunky`'s Avatar
In absolute terms, I have yet to see a B-series that is making 200+ lb-ft of torque at 10k rpm.
Forget about the midrange, look at absolute numbers. It doesn't matter if the torque is rising or falling; if the ACTUAL torque is greater, you will be going faster. Period.
I don't think you quite realize how difficult it is to sustain torque production on a big displacement motor into high revs.
__________________
Twisted Loop Racing
Old 07-14-2008, 10:57 AM   #35
unsivil_audio
K20a.org Basic User
You may be right, I dont think its rocket science either though.
A 2nd look at that dynograph though, and that would be a totally accpetable powerband for me (considering I'm only wanting to rev to 8500 or so). If I could have that on a street car but at a lower power level I would be perfectly happy.
__________________
Old 07-14-2008, 11:31 AM   #36
TheMidasTouch
K20a.org Basic User
Thats the thing mang, if your torque is still rising then your red line needs to get pushed. Realistically, you don't want to shift until your overall thrust curve per gear intercepts the next one.
This means that your torque will need to be decreasing fast enough by rpm so that your hp output times the gear multiplier equals the next gears output at the given intercept speed. So on any well targeted/designed motor, torque should always fall off hard before red line. Its what you use to gauge where red line really should be.
On some unbuilt B-series, raising the red line isn't an option so to make the most peak whp tuners(on demand most of the time) will push the torque as high as possible in the rpm range ignoring power band because of what you were saying(20whp for 10lbs of torque) Which, for anyone who doesn't know already, comes from the calculation for Horse Power. HP is really only a function of torque vs rpm.
HP = (Torque * RPM)/5252
Old 07-14-2008, 11:44 AM   #37
signalpuke
signalpuke's Avatar
Thanks for the well worded explanation. That is what I was trying to convey with the 15k redline comment, I wasn't trying to be an ass lol.
__________________
[SIGPIC][/SIGPIC]
New to the K-Series? ☆★☆★ DIY and FAQ ★☆★☆ <------- CLICK THE LINK!
Otatsiihtaissiiststakio piksi makamo ta psswia
signalpuke is offline   Reply With Quote Quick reply to this message
Old 07-14-2008, 11:54 AM   #38
TheMidasTouch
K20a.org Basic User
Oh man, I wasn't referencing your post, and I agree with you of course. I was just wording the concept differently. Different strokes for different folks when were learning.
Really though, traction willing, we want more of all(torque, gearing, rev stability, etc...) in all rpm ranges
Old 07-14-2008, 12:33 PM   #39
chunky`
Lifetime Member
chunky`'s Avatar
As far as delaying a sharp torque falloff in a high displacement 4 banger? It's not rocket science, but there is a science to it.
Anyhow, just compare the raw numbers on torque for a 2.0L b-series and a 2.0L k-series at 8000rpm. The K-series is no high RPM slouch. You can build a k-series that loves to rev, that is reliable, and that isn't ridiculously expensive.
It won't have the same power delivery as the b-series, but you'll be going faster regardless of how the power delivery feels.
Anyhow, if you're looking to rev to 8500, check out my latest dyno. It's pretty linear in the RPM range you specified, but I'm hoping that a better header will bring up my midrange even more to 160+ lb-ft of torque.
__________________
Twisted Loop Racing
Old 07-14-2008, 12:36 PM   #40
unsivil_audio
K20a.org Basic User
Quote:
I agree, I more or less think engine building is an artform. It takes a very fine tuned piece to amaze the masses.
BTW, your dyno looks good, however I'm gonna venture a guess and say that you have a k20 judging by that torque curve.
__________________
Reply
Bookmarks
Tags
tuning, vtc, vtc tuning
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Thread Tools
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
