Press Release from IPS : IPS-K2 8620 produces highest output on K20a Type R motor - K20A.org .:. The K Series Source . Honda / Acura K20a k24a Engine Forum
Reply
Thread Tools
Old 01-23-2007, 08:01 AM   #1
nikos
K20a.org Master User
nikos's Avatar
Default Press Release from IPS : IPS-K2 8620 produces highest output on K20a Type R motor
For immediate release from www.intrinsicperformance.com
January 23, 2007
IPS-K2 8620 produces highest output on internally stock K20A ever recorded at
Church Automotive Testing's Dynapack 4000!
Engine Setup:
JDM K20A type r stock
SSR header
PRC vs. RBC intake manifold
CAI with Prototype Racing Velocity stack
91 octane
Hondata K-Pro
I believe the car is a RHD EK. If I find out any more information about this, I will let you guys know.
nikos is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 01-23-2007, 08:03 AM   #2
nikos
nikos's Avatar
Default Re: Press Release from IPS : IPS-K2 8620 produces highest output on K20a Type R motor
As you can see this is PRC vs RBC from the image description
Old 01-23-2007, 08:03 AM   #3
tony4380
tony4380's Avatar
wow those numbers are up there.... thanks nikos for posting... and great job to IPS!!
__________________
K'd UP
01-28-06 >> 13.11 @107.50 2.03 60ft
01-27-07 >> 12.70 @107.41 1.91 60ft
[email protected] >>[email protected]
tony4380 is offline   Reply With Quote Quick reply to this message
Old 01-23-2007, 09:29 AM   #4
jdmk20ahatch
Quote:
but which is which? Is the RBC top or bottom? I imagine top but ? 16 hp is kinda alot up there
jdmk20ahatch is offline   Reply With Quote Quick reply to this message
Old 01-23-2007, 09:32 AM   #5
Vteckidd
K20a.org Advanced User
so 240-245 on a dynojet.
thats really impressive, great numbers
__________________
KIDDRACING
[email protected]
AIM: Vteckidd
Vteckidd is offline   Reply With Quote Quick reply to this message
Old 01-23-2007, 09:34 AM   #6
nikos
nikos's Avatar
Not really. RBC has gained 18-20whp on 4 different cases so far.
Here's an older dyno from Locash, Hasport's tuner
PRC (dotted) vs. RBC (solid) with open header
The PRC made 225whp and the RBC made 237whp
So yeah, it is proven that the RBC is a major improvement. I know it first hand because I also used it on my own car. Not sure how long you have been reading on k20a.org, but there are a dozen K motors making a lot of power with RBC
Old 01-23-2007, 09:44 AM   #7
Vteckidd
it is true, chunkys motor gained alot up top from what i saw
__________________
KIDDRACING
[email protected]
AIM: Vteckidd
Old 01-23-2007, 09:49 AM   #8
memphisraines26
New Member
memphisraines26's Avatar
is the RBC the 06 civic si intake manifold?
memphisraines26 is offline   Reply With Quote Quick reply to this message
Old 01-23-2007, 09:51 AM   #9
jon v
Lifetime Member
jon v's Avatar
Quote:
yes...
Nikos, can Ron confirm that there has yet to be any revisons to the profiles of the new 8620 K2's, or any of his cams for that matter?
I wonder how much i ccould get a new set of 8620 KME's for...
__________________
Quote:
Originally Posted by Mr.E.G.
think about what you are saying here. educated people are saying that some portions of this safety device are in direct conflict with this little thing called physics and you are willing to ignore that simply because of the cage builders reputation? that sounds like religion to me. welcome to the church of fanboyology.
jon v is offline   Reply With Quote Quick reply to this message
Old 01-23-2007, 10:01 AM   #10
memphisraines26
New Member
has there been much profile difference since the K2s were first produced? I would like to get a set and see several used but was wondering if I should buy new if there have been any improvements.
Old 01-23-2007, 10:13 AM   #11
nikos
nikos's Avatar
Quote:
Originally Posted by jon v
yes...
I cannot speak for Ron on that matter. When he does implement such revisions, I am sure you are going to know about it. One of the features of the 8620 material is that the profile gets implemented in better detail.. Same cam master but more precise grinding wheel... That is my opinion awyway.
Old 01-23-2007, 10:33 AM   #12
jdmk20ahatch
I thuogh I knew which was which just making sure. Ive heard people say yeh it makes more power on clubrsx/ephatch and such, but just that only heard no dyno #s. I have only just started reading head about a month or two here but not new Been on H-T for 4 years or so. Have had my EP for almost 3 years but just picked up a k20z1 short block and been reading up on the different options. Dont really wanna get a RBC mani because i would like to retain my mugen intake(hoping the Hytech manifold 6spdEK has will be as good or better for that reason), but i imagine where theres a will theres a way i can always manage something with the Samco intake hose i imagine
Old 01-23-2007, 10:47 AM   #13
Yasei
K20a.org Basic User
Yasei's Avatar
Surprisingly this press release came out just after the results from IPS K2 vs. Skunk stage2 comparison test. Makes me wonder when this would have been released if the test results came out when they were planned to be released
Yasei is offline   Reply With Quote Quick reply to this message
Old 01-23-2007, 11:31 AM   #14
Vteckidd
Quote:
expect both sides to start politicin' soon.
Maybe Clinton will drop by an tell us what she thinks of the 8620s, thats what we all care about
__________________
KIDDRACING
[email protected]
AIM: Vteckidd
Old 01-23-2007, 11:43 AM   #15
MJ23FE
Lifetime Member
MJ23FE's Avatar
It is also surprising that the ductile iron IPS-K2's made more power than the Skunk2 Stage 2's 89% of the time. Averaging 10whp/wtq more between 5700rpm-6200rpm.
-Jalal
__________________
TeamXXXRacing
SoHonda Garage.
RIP Adam West
You were a great person.
MJ23FE is offline   Reply With Quote Quick reply to this message
Old 01-23-2007, 11:50 AM   #16
memphisraines26
New Member
so the IPS-K2 8620 is just a newer matieral but same profile as the previous K2s? I just want to get the best cam set of the 2 since i can find the K2s used.
Old 01-23-2007, 11:52 AM   #17
MJ23FE
Lifetime Member
MJ23FE's Avatar
Yes.
-Jalal
__________________
TeamXXXRacing
SoHonda Garage.
RIP Adam West
Old 01-23-2007, 11:53 AM   #18
9bells
9bells's Avatar
Impressive. Looks like even the 8620's are worth every penny.
__________________
"Don't tell me about money. You can sleep in a car, but you can't race a house!"
unobtainium welding
9bells is offline   Reply With Quote Quick reply to this message
Old 01-23-2007, 12:00 PM   #19
SchueString Racing
Lifetime Member
Quote:
Originally Posted by MJ23FE
Yes.
-Jalal
Shame on you!
__________________
Coming soon!
SchueString Racing is offline   Reply With Quote Quick reply to this message
Old 01-23-2007, 12:01 PM   #20
GST2RSX-S
January 23, 2007
http://www.intrinsicperformance.com/...RBC-vs-PRC.gif
Engine Setup:
SSR header
91 octane
Hondata K-Pro
EDIT: IPS-K2 8620 CAMS
Nice! At first I thought you were saying that the IPS-K2 cams produce more power than anything out there including Skunk2 Stage2 cams. No (peak power was just shown otherwise)... Then, I realized that you were talking about new cams from IPS called: IPS-K2 8620. Then, I looked at the "Engine Setup," and thought wow, so there is NO cams in this motor, it's internally stock, and its a "JDM K20A type r stock"? I finally realized, that indeed the motor has cams called IPS-K2 8620. I fixed the post in the quote to be more clear.
Call me a nitwit, but I was confused there for a while.
Now, I realize that these are very nice cams, and that's what we're talking about.
GST2RSX-S is offline   Reply With Quote Quick reply to this message
Reply
Bookmarks
Tags
ips, ips k2's
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Thread Tools
Posting Rules
You may not post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
