How do you block off the coolant port on tsx head? - Page 3 - K20A.org .:. The K Series Source . Honda / Acura K20a k24a Engine Forum
Reply
Thread Tools
Old 09-08-2011, 03:38 AM   #41
signalpuke
K20a.org Master User
signalpuke's Avatar
Default Re: How do you block off the coolant port on tsx head?
http://www.boltdepot.com/fastener-in...read-Sizes.pdf
__________________
[SIGPIC][/SIGPIC]
New to the K-Series? ☆★☆★ DIY and FAQ ★☆★☆ <------- CLICK THE LINK!
Otatsiihtaissiiststakio piksi makamo ta psswia
signalpuke is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 09-08-2011, 03:44 AM   #42
drtye
Lifetime Member
drtye's Avatar
ok, what i was saying is for a 3/8 npt you need a drill bit (or a hole to tap into of appx 9/16")
heres a chart, hopefully it helps.
http://www.kramerusa.com/DrillTapChart.htm
drtye is offline   Reply With Quote Quick reply to this message
Old 09-08-2011, 03:55 AM   #43
mocchi
Lifetime Member
mocchi's Avatar
thanks alot for the info aaron, tye. you good men.
no homo
__________________
DIY link
mocchi is offline   Reply With Quote Quick reply to this message
Old 03-04-2012, 08:02 AM   #44
DC2Bobby
K20a.org Basic User
sorry for posting on an old thread but I have a quick question, does the hole need to be drilled before tapping it or is it already the proper size?
DC2Bobby is offline   Reply With Quote Quick reply to this message
Old 03-04-2012, 08:27 AM   #45
e78704
Quote:
I just force the 3/8" tap in there and start working it. If your tap happens to have a really fat snout, you might need to open up the coolant orificie a little with a burr grinder.
Hope this helps.
e78704 is offline   Reply With Quote Quick reply to this message
Old 03-22-2013, 04:52 PM   #46
aztec1382
K20a.org Basic User
aztec1382's Avatar
Default
Just did this mod
Thanks for the info
3/8 npt to -10
-10 90 push lock fitting
Just make sure you tap the 3/8 coolant port at an angle away from the manifold to make sure you clear it
aztec1382 is offline   Reply With Quote Quick reply to this message
Old 03-25-2013, 07:02 PM   #47
Mixwell
k20a.orgy
Mixwell's Avatar
Default
And I heard that hasport plate leaks. Can anyone confirm if they've tried it?
__________________
.........................issforged wheels.........................
=====>MIXWELL'S s2k24a2 PROJECT<=====
Mixwell is offline   Reply With Quote Quick reply to this message
Old 03-28-2013, 09:41 PM   #48
2thoj
New Member
Quote:
Originally Posted by aztec1382 View Post
Just did this mod
Thanks for the info
3/8 npt to -10
what size plug did you use for the egr port? 3/4 or 1/2?
2thoj is offline   Reply With Quote Quick reply to this message
Old 03-29-2013, 06:25 PM   #49
JCRasta
New Member
What if you had a k20 skunk 2 manifold like so http://store.skunk2.com/engine-tunin...fold-1462.html
Wouldn't it work on a k24a2 if you just plug the water neck coming out of the side? The gaskets are almost identical leaving the water port which you tap with the 3/8 open to run through and connect to the thermostat neck.
JCRasta is offline   Reply With Quote Quick reply to this message
Old 04-03-2013, 09:41 PM   #50
aztec1382
K20a.org Basic User
aztec1382's Avatar
Default
Ports don't line up , you can buy there tsx manifold which will work
Old 04-04-2013, 10:34 AM   #51
eK24monster
eK24monster's Avatar
Ports don't line up
All the ports line up. The picture of the manifold you linked to is by design... universal. It will fit the PRB, RBB, RBC, RAA, and PPA cylinder heads. If you have the PRB head and need the water port... you would simply install the water neck. If you own any of the other heads... you simply plug it. This manifold may still exist in the market place but is no longer shipping from Skunk2.
Not to confuse the matter any further but to make everyone aware of some changes at Skunk2, Skunk2 has started chopping the universal water neck portion of the manifold off making a unique part number for the PRB guys.
The only other part number offered still keeps that cast in water neck but is only meant for the 06+ Civic Si customers. It has a throttle body flange specific to that application and is void of an IAC port. If you have a swap using that style head... you will need to buy a throttle body adaptor. If you want IAC function... you will need to port the manifold flange.
eK24monster is offline   Reply With Quote Quick reply to this message
Old 04-04-2013, 01:02 PM   #52
JCRasta
New Member
Thats what i thought, i just got confused as to why on the site they seperated it to only the rsx. But what would i search for to find this block off Im having no luck. Thank you very much.
Old 04-04-2013, 02:23 PM   #53
eK24monster
Quote:
Confused? I thought you were talking about running the manifold. You dont need to plug or block anything off. The only time you need to block anything off is if you want to run a manifold that was meant for the PRB head or you want to modify a manifold (meant for the head like this: https://www.facebook.com/photo.php?f...type=3&theater) eliminating the coolant passage.
Old 04-04-2013, 03:25 PM   #54
JCRasta
New Member
This is the manifold I would like to use. http://s1145.photobucket.com/albums/...224_114328.jpg the water neck is coming off the side. I would like To use this with the k24a2 . I know I can cut the entire water neck off like the black sk2 manifold previously post and do the 3/8 fitting but it seems as if the manifold could just work if I unscrewed the water neck and replace it with a sort of block off. I'm running a non modified Rbc right now on it and the gasket used is almost identical to the one I have for the skunk 2 manifold.
Old 04-04-2013, 11:05 PM   #55
eK24monster
If you buy that manifold... it will work on ALL K Series heads.
Old 04-09-2013, 02:25 PM   #56
fckuall
K20a.org Basic User
fckuall's Avatar
so 3/8" NPT -18 tap is what I am looking for?
Is this what I want?
http://www.harborfreight.com/6-piece...set-91395.html
fckuall is offline   Reply With Quote Quick reply to this message
Old 04-09-2013, 07:35 PM   #57
aztec1382
K20a.org Basic User
aztec1382's Avatar
Default
Old 04-10-2013, 12:21 PM   #58
fckuall
K20a.org Basic User
fckuall's Avatar
Is that a No?
trying to find this tap is very confusing as everything comes up 3/8" NPT. But I am gathering that is wrong.
I need something that says 3/8 NPT? If someone has a link to the tap they used that would be great.
Old 04-10-2013, 01:48 PM   #59
eK24monster
Sometimes you have to do things for your self bud! Stop looking for hand outs...
SEARCH 3/8 NPT tap on the internet and you will see that it requires a 3/8" -18 tap and a 37/64ths. drill or hole. You can alternately use a 9/16ths. drill or hole.
The guy above gave you a chart that spelled it all out.
Old 04-10-2013, 03:20 PM   #60
fckuall
K20a.org Basic User
fckuall's Avatar
ok so it is the right thing then. A simple yes would have worked. I don't see how asking for conformation before I buy the tap is considered a handout. If you want to send me your tap I'll happily accept and consider that a handout.
This thread is very confusing.
So 3/8" NPT is the same as 3/8 NPT...
I already have a hole so I don't care about the drill size.
Reply
Bookmarks
Tags
coolant, coolant port, head, k20z3, k24a2, port, rbc, rrc, tsx
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Thread Tools
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
