vtec killer, k20a3, gt35@14psi need help with best vct angle under boost - K20A.org .:. The K Series Source . Honda / Acura K20a k24a Engine Forum
Reply
Thread Tools
Old 02-09-2016, 09:44 AM   #1
cbales333
New Member
Default vtec killer, k20a3, [email protected] need help with best vct angle under boost
hi I've searched high and low for some good vct angles under boost for my vtec killer setup and ive come up dry. 3 posts I read said they go as high as *45 or *50 with no valve interface, one guy said he bent 7 intake valves going above *30? my highest angle ive gone is *25 with no problem but I want to go higher because I was still building torque in my midrange with the more vct advance I gave it. let me know if you guys have any info.
thanks,
cody
cbales333 is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 02-09-2016, 07:24 PM   #2
kr3w108
K20a.org Advanced User
kr3w108's Avatar
Default Re: vtec killer, k20a3, [email protected] need help with best vct angle under boost
You have a very vague description of setup.... would need to know what is in the motor . Cams,piston setup. Is it a stock motor? Stuff like that is key.
__________________
Best ET [email protected]
IG: J_Lizzzle : Fullforcemotorsports //FullForceMotorsports // Work Turbo // Prayoonto Racing
kr3w108 is offline   Reply With Quote Quick reply to this message
Old 02-10-2016, 08:49 AM   #3
cbales333
New Member
its a base k20a3 block and head (k20a3 pistons), the only mods to the block is ive installed oil squitter's, and ive put type s springs and retainers. I have a gt35r82 pushing 12 to 14 psi. it has a vtec killer setup with z3 cams in it. my main question is how much VCT angle can I give it without the intake valves hitting the pistons. im still building midrange torque @ *25 angle and id like to push it until torque starts to drop.
thanks,
cody
Old 02-10-2016, 09:02 AM   #4
cbales333
New Member
here's a pic. the only outside mods I have is a vacuum pump hooked up to the valve cover breather that comes on under boost, its hooked up to a exhaust venturi in my exhaust cut out (12psi closed exhaust, 14psi open exhaust) it also has a external air/oil cooler. also has water/meth injection
Old 02-10-2016, 07:34 PM   #5
kr3w108
kr3w108's Avatar
Quote:
This is still stock A3 rods? If so this motor will not last very long.
__________________
Old 02-11-2016, 05:30 AM   #6
cbales333
New Member
I know the capability of the A3, forums don't give it much credit but for a complete engine you can buy for $500 and get 400hp out of it that's impressive to me. ive had the turbo on the engine for 3 years with lots of abuse and it hasn't let me down, I just recently did the cam killer in hopes to get a little more out of it. that's why im here asking and looking around for a good answer before I push my angle past *25.
thanks,
cody
Old 02-11-2016, 09:17 AM   #7
D-Rob
D-Rob's Avatar
I have run that setup to 40deg without issue in the past. Go for it.
__________________
'98 Honda Civic Coupe :: K20A2-Powered, Full-Race, T3/T67-Motivated :: 697whp / 448wtq @ 27psi on E85, STOCK BLOCK, 11.0 @ 143mph, 2760lbs.
InnovativeMotorWorks
D-Rob is offline   Reply With Quote Quick reply to this message
Old 02-11-2016, 07:18 PM   #8
kr3w108
kr3w108's Avatar
Im only speaking on behalf of my ep3. lol it lasted little over a year at 260hp and then gave up the ghost. Got that window block .
__________________
Reply
Bookmarks
Tags
kal, kpro, turbo, vct, vtec killer
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Thread Tools
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
