Euro R manifold VS ITR manifold ( RBC vs PRC ) - Page 3 - K20A.org .:. The K Series Source . Honda / Acura K20a k24a Engine Forum
Reply
Thread Tools
Old 03-09-2005, 10:53 AM   #41
RoadRunner Type S
Default Re: Euro R manifold VS ITR manifold ( RBC vs PRC )
Subscribed....
RoadRunner Type S is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 03-10-2005, 06:55 PM   #42
Dc5itracer
K20a.org Basic User
Dc5itracer's Avatar
Looks like we got some friendly faces from clubrsx
Dc5itracer is offline   Reply With Quote Quick reply to this message
Old 03-10-2005, 07:00 PM   #43
diggs
New Member
Quote:
subscribed....
diggs is offline   Reply With Quote Quick reply to this message
Old 03-10-2005, 07:01 PM   #44
PapiTuyo326
K20a.org Master User
PapiTuyo326's Avatar
thread got more interesting since i last checked it out.
__________________
I always stock K20a2, K24a2, and K24a1 Swaps at competitive prices.
Longblocks and Full Swaps available. PM for more info.
PapiTuyo326 is offline   Reply With Quote Quick reply to this message
Old 03-10-2005, 08:02 PM   #45
SchueString Racing
Lifetime Member
Quote:
Originally Posted by Dean NZ
Toda Pwr - don't suppose you could measure the manifold from the flange face to the outer most section of the plenum in a horizontal plain ?
And maybe a depth downwards from the centre of one of the flange bolt holes ?
Want to see if this will fit in my car ?
What car? Here is the manifold inside my dc5 engine bay(check out the k2s!)
__________________
Coming soon!
SchueString Racing is offline   Reply With Quote Quick reply to this message
Old 03-12-2005, 02:16 AM   #46
Dean NZ
New Member
Toda Pwr can you provide a measuremt of the manifold from the flange face to the outer most section of the plenum casing in a horizontal plain ?
And maybe a depth downwards from the centre of one of the upper flange bolt holes ?
Want to see if this will fit in my car ? Lotus Elise ???????
PLEASE !
Cheers Dean
Dean NZ is offline   Reply With Quote Quick reply to this message
Old 03-12-2005, 05:38 PM   #47
typesfanatik
so will this euro r manifold fir the k20a2 in the type s
and is it better then the ITR IM when it comes to running the ITR cams and ITR reflash
typesfanatik is offline   Reply With Quote Quick reply to this message
Old 03-12-2005, 07:47 PM   #48
Rubber Chicken
Before you all jump and buy RBC manifolds - I've done before and after dynos with the PRC vs RBC manifold on 3 different engines, and the gains from the RBC over the PRC are marginal. One engine was better on the PRC manifold, one was almost the same, and one engine made a more after peak power (the power did not fall away quite a quickly). We're talking -2 to +5 hp from the manifold. The RBC has the same length and size runners and the same plenum volume, the runners are just a little straighter than the PRC.
Rubber Chicken is offline   Reply With Quote Quick reply to this message
Old 03-12-2005, 09:52 PM   #49
GT MOTORING
K20a.org Basic User
Quote:
Derek,
just so i know, and others, did the peak torque numbers change there location in the power band at all?
__________________
www.gtmotoring.com greg @ gtmotoring.com
GT MOTORING is offline   Reply With Quote Quick reply to this message
Old 03-13-2005, 06:01 AM   #50
Rubber Chicken
Quote:
Peak torque rpm was a little lower with the RBC, but it was not a huge difference. The main gains were in the 6500 - 7500 rpm range, and after peak power. I'll see if I can dig out an old dyno.
Old 03-13-2005, 06:04 AM   #51
GT MOTORING
K20a.org Basic User
Great, thanks for helpin out.
__________________
Old 03-13-2005, 08:04 AM   #52
typesfanatik
so i guess ill aks again can i assume this will fit on the type s motor
Old 03-13-2005, 08:08 AM   #53
Dc5itracer
K20a.org Basic User
Dc5itracer's Avatar
this manifold is good for boost applications though.I read somewhere it made a 17whp diffrence than the prc correct me if i am wrong
Old 03-13-2005, 08:09 AM   #54
GT MOTORING
K20a.org Basic User
Quote:
yes it fits on a type S motor in an RSX. some modification is needed to the manifold.
__________________
Old 03-13-2005, 08:10 AM   #55
H2nr
K20a.org Advanced User
H2nr's Avatar
Location: 2nrs of Springfield home of the fastest Hondas in the 417 area since 1997
Speed wrex , are you stocking these yet?
__________________
My s2000 757hp510tq
www.facebook.com/2nrsOfSpringfield
H2nr is offline   Reply With Quote Quick reply to this message
Old 03-13-2005, 08:12 AM   #56
GT MOTORING
K20a.org Basic User
Quote:
ive had alot of lookers, no buyers. im not stocking them til i have someone committed. special order only. 2 week wait.
__________________
Old 03-13-2005, 08:19 AM   #57
H2nr
H2nr's Avatar
I PMed you and I have money
__________________
My s2000 757hp510tq
Old 03-13-2005, 09:46 AM   #58
Rubber Chicken
Here's a dyno graph from a stock K20A engine. Yellow is the RBC, purple is the PRC. The gain between 6000 and 7000 rpm from the RBC is typical. You can't quite see the difference on the top as the PRC was not revved as high, but the RBC tends to hold peak power longer.
Old 03-13-2005, 12:11 PM   #59
SchueString Racing
Lifetime Member
Thanks for the graph. I think this manifold will compliment my IPS K2s quite well.
Old 03-13-2005, 12:28 PM   #60
typesfanatik
what modification is needed??
is it a DIY job or need to be machined in a shop
oh and what is he cost of this manifold
Reply
Bookmarks
Tags
manifold, prc, prc vs rbc, rbc, rbc vs prc
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Thread Tools
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
