My k20a Cant Make Power!!! - Page 2 - K20A.org .:. The K Series Source . Honda / Acura K20a k24a Engine Forum
Reply
Thread Tools
Old 03-04-2015, 02:22 AM   #21
Sil24
New Member
Default
Here some picture of my engine when it rebuild last time
Sil24 is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 03-04-2015, 05:51 AM   #22
LotusElise
LotusElise's Avatar
Default Re: My k20a Cant Make Power!!!
Thanks for the pictures and additional information (RRC, two tuners)
Quote:
Originally Posted by Sil24 View Post
..My only chance is to change the injector ang hope its will gain some power..
Before that I highly recommend you Sil24 to check, as stated before by doug2507, the duty cycle value of the injectors in a datalog in the area of redline. I saw many setups with stock 330 cc injectors from Denso producing power like yours and more...duty cycle of 90 % is reached in the area of 240-255 whp (depends on some parameters like AFR, engine efficiency, ...). Just check this please to get it clarified quick and cheap.
I see some good power potential of your setup for beyond 240 whp, a not nice torque shape (please clarify if this is fully tuned), a interessting shapped CAI pipe and an unclear calibration.
The solution process gets warmed up even if you keep your calib. like a secret . Next step, could you please do a leak down test of every cylinder? Just to get out a liner-piston ring or valve clearance issue out of that equation.
Thanks
LotusElise is offline   Reply With Quote Quick reply to this message
Old 03-04-2015, 06:51 AM   #23
Sil24
New Member
Default
What u mean by i need to check value injector in datalog in red line are??
The tuner only give the piece of paper for the tuning result just like i show u in the images attach..
Bydaway how to check if u dont mint to share with me..
Yes i believe it fully tune.. You dont think so?
Old 03-04-2015, 07:15 AM   #24
LotusElise
LotusElise's Avatar
Don't you have a FlashPro-System (Datalogging and Mapping-option)?
Source: www.hondata.com
But "...FlashPro connects from your laptop's USB port to your vehicles diagnostic port to provide live tuning with a variety of calibrations, extensive real time and stored datalogging capabilities." (s. www.hondata.com). You do have this option, don't you?
First you need the software to down- and upload the calib.- and datalogging files: the FlashProManager. You find on the website stated above or here. Install it and check your mapping by connecting the FlashPro to your computer. Ok?
Yes i believe it fully tune.. You dont think so?[/QUOTE]
Old 03-04-2015, 02:39 PM   #25
Sil24
New Member
Default
I see.. Myb i should try later on
Old 03-07-2015, 11:02 AM   #26
K20actr.J
K20a.org Basic User
K20actr.J's Avatar
Hello guys,
i have done several Mod on my k20a FD2R Jdm on my car but seem like the the engine doesnt make power what like im expecting.
here my mod below
Toda A3 cam
Toda Valve Spring
87mm wiseco piston
BC conrod
skunk2 extractor header
custom 3inch exhaust piping with spoon N1 Muffler,
port Polish head
Custom CAI with 4inch air filter
J37 TB,
Hondata Flashpro
with all this setup i only manage to get 236hp
i wonder where is wrong at my engine setup.. anyone can advice me on this..
your problem i believe its not the cams.toda a2 and a3 are very reliable cams and make good power. I had a2 and a3 with 275 hp crank 2 liter and now A3 300 hp crank 2157 cc and STOCK head.. your issue is j37 i believe.Go with STOCK t/b. A3 cams have big duration (295/290) and have no anything to do with any dic cams..
K20actr.J is offline   Reply With Quote Quick reply to this message
Old 03-09-2015, 02:45 AM   #27
Sil24
New Member
Default
Seriously?? What is your mid?
What u mean by j37 is the prob? Dont u think highcam need more air to process the air to the engine?
Old 03-09-2015, 10:48 AM   #28
K20actr.J
K20a.org Basic User
K20actr.J's Avatar
with 70mm t/b made 300.Ι tryed 74mm t/b and losted 20hp from v-tec to 9300 on dyno with my tuner.After replaced again 70mm t/b and wοn the lost power.Probably you lose air speed flow
Old 03-10-2015, 07:45 AM   #29
02sik24a2
Lifetime Member
02sik24a2's Avatar
I dont have the datalog measurement as you mention.. Only the dyno graph
Is your cylinder header port matched to your intake manifold..?
87mm bore may require a larger cam to keep volumetric efficiency going in the higher revs.
You will bust [email protected] the wheels without changing cams. Just do a port match at intake manifold and cylinder head. use 70mm throttle body matched to RRC inlet. Use a straight 3"intake tube ending in velocity stack/filter combo dealO. Use a 3" muffler with turn down. Re-tune.
If you change the cam, do everything above and a portNpolished RRC. While the backside of the RRC plenum is off, doing the intake port matching is much easier. It makes it easier to match the Hondata plastic intake manifold gasket as well. Re-tune. While you are tuning this kind of set up, try a 3"X4" intake pipe and see if it likes a large opening.
__________________
Loving life = Giving Life : Hating life = Taking Life
02sik24a2 is offline   Reply With Quote Quick reply to this message
Old 03-10-2015, 09:57 AM   #30
_Mozz_
K20a.org Master User
The TB he uses is 70mm . . .
__________________
- FN2 - Ultimate Street Stroker Build -
https://www.k20a.org/forum/showthread.php?t=99260
_Mozz_ is offline   Reply With Quote Quick reply to this message
Old 03-11-2015, 01:08 PM   #31
02sik24a2
Lifetime Member
02sik24a2's Avatar
Quote:
I agree with the OP in the conclusion 70mm TB is better than the 74mm TB, thus " USE 70mm TB " - said by me in relation to fixing the OP's problem as you.
Am I in need of your correcting . . .
__________________
Old 03-11-2015, 02:31 PM   #32
K20actr.J
K20a.org Basic User
K20actr.J's Avatar
My opinion is that to try stock t/b..maybe i do mistake
Reply
Bookmarks
Tags
honda civic k20 k24, jdm, k20a, mod, type r
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Thread Tools
Posting Rules
You may not post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
