DIY: K24a1 K20a3 IMRC Delete P0661 P0662 P1077 P1078 etc. - K20A.org .:. The K Series Source . Honda / Acura K20a k24a Engine Forum
Reply
Thread Tools
Old 05-20-2014, 05:37 PM   #1
nbleak21
K20a.org Basic User
Cool DIY: K24a1 K20a3 IMRC Delete P0661 P0662 P1077 P1078 etc.
For any of you with IMRC woes (or those who just want to run a different IM w/o k-pro) you may find the following helpful.
Over the past year (12,000 miles) I've been running an IRMC Delete/bypass circuit (simple relay switched voltage divider) that I created since it was cheaper then fixing the actual IMRC issues.
The circuit can be made in under an hour with a soldering iron and $11 in parts from amazon, ebay, radioshack or other electronic component retailers.
Circuit Diagram:
IMRC Circuit MOD1 (based off schematic above):
TSX IM installed on my 2002 RSX Base auto k20a3 (I believe I am the first!):
I'm currently looking to source compatible plugs for the IMRC emulator for direct plug and play installation, if anyone has any tips on where to find the 2-pin solenoid plug and 3-pin IMRC sensor plug please do tell!
For more info, my original thread is on CRSX here: http://forums.clubrsx.com/showthread.php?t=863589
nbleak21 is offline   Reply With Quote Quick reply to this message
Reply
Bookmarks
Tags
k20a3, k24a1, p0661, p0662, p1077
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Thread Tools
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
