K-Tuned Oil Pan Kit - Page 2 - K20A.org .:. The K Series Source . Honda / Acura K20a k24a Engine Forum
Reply
Thread Tools
Old 12-29-2013, 07:22 PM   #21
JDM96SpecCTR
K20a.org Master User
JDM96SpecCTR's Avatar
Default Re: K-Tuned Oil Pan Kit
so its no better than an oem pan... is it cheaper?
__________________
TEAM EXiT
Midnight Auto
EvaUnit01: nope, the american dream is a fully finished car with a K24/k20 setup.
JDM96SpecCTR is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 12-29-2013, 11:19 PM   #22
richi
New Member
...it could be cheaper because the price of the chinese manufacturer is very low, I think ;)
richi is offline   Reply With Quote Quick reply to this message
Old 12-30-2013, 06:11 AM   #23
[email protected]
Quote:
Originally Posted by TravisRSX View Post
Did that statement not make people scratch their heads? Most likely meaning it wasn't actually tested properly? Why would you chance it when you can use the OEM steel pan?
The OEM pan and our K-Tuned pan are extremely similar. They are both steel and both will only dent if they are hit hard enough. Obviously we all want to avoid having our oil pan hit anything, but sometimes things happen. The comparison being made in the product description is between an aluminum pan and a steel one. If contact does occur would you prefer a dented steel pan? Or an aluminum pan that completely shatters and looks like the one below?
Quote:
Originally Posted by Scourge View Post
Will this work with the K24A2 or K20Z3 oil pump (with balance shafts)? I like having them on a daily to reduce vibrations. I'm getting old. Lol. Have tons of grey already.
Sorry these do not fit with the balance shaft oil pumps. A deeper pan is needed.
Quote:
Quote:
As I said above, the OEM pan and our K-Tuned pan are extremely similar.
These are priced very well when you consider that you are getting a complete kit with hardware and the magnetic drain bolt.
Mike@K-Tuned is offline   Reply With Quote Quick reply to this message
Old 12-30-2013, 06:20 AM   #24
brakaT
brakaT's Avatar
How much for the just the magnetic drain bolt? Need to make a order soon and would like to get this.
__________________
2000 CW JDM RHD ITRx
Neighbourhood Troll
brakaT is offline   Reply With Quote Quick reply to this message
Old 12-30-2013, 12:11 PM   #25
iBoost
iBoost's Avatar
Quote:
The answer is "What is a dented steel pan" Alex Trebek...
__________________
||| AutoFair Honda ||| K-Tuned |||
D-Rob - Innovative MotorWorks Tuned
iBoost is offline   Reply With Quote Quick reply to this message
Old 12-30-2013, 12:34 PM   #26
[email protected]
LOL Josh.
Old 02-10-2014, 04:46 AM   #27
[email protected]
Up we go.
Old 02-11-2014, 05:14 PM   #28
redgsrguy
K20a.org Basic User
redgsrguy's Avatar
Is ground clearance better than OEM? Thinking of getting a steel pan with baffles to replace my Moroso which sits slightly lower than OEM.
redgsrguy is offline   Reply With Quote Quick reply to this message
Old 02-12-2014, 09:54 AM   #29
[email protected]
Ground clearance compared to the oem steel pan is identical.
Both the oem steel pan and ours will give you 1/2" to 3/8" more clearance when compared to the oem aluminum oil pan.
Old 03-24-2014, 07:37 PM   #30
ChaseIntegra
K20a.org Advanced User
ChaseIntegra's Avatar
Ordering mine tonight. My car is at the body shop for engine bay paint. Gonna get a steel pan so we can swap it out real quick while the engine is on the hoist!
ChaseIntegra is offline   Reply With Quote Quick reply to this message
Old 03-25-2014, 09:00 AM   #31
[email protected]
Sounds good Chase.
Old 03-25-2014, 02:06 PM   #32
ChaseIntegra
Got a tracking number this afternoon when I woke up! Thanks a lot Mike!!
Old 03-27-2014, 06:14 AM   #33
[email protected]
No problem. Happy to help.
Old 09-18-2015, 07:08 PM   #34
ChaseIntegra
DSC_3416-2 by Chase Shands, on Flickr
DSC_3436-2 by Chase Shands, on Flickr
Old 09-19-2015, 05:59 PM   #35
kb58
If you had a blank-sheet design, how close to the road would you let the oil pan be? I did do a blank-sheet design (www.midlana.com) and can't imagine running any less than 4" under the pan. The analogy I use in my book is that running a heavily-lowered car on the street is like swimming naked over sharp rocks in shallow water... you can do it, but you're pushing your luck and risk "snaggage."
__________________
midlana.com:Turbo K24-powered mid-engine Super 7, and the book on how to build your own!
Kimini book: Mid-engine sports car design using a FWD drivetrain.
kb58 is offline   Reply With Quote Quick reply to this message
Old 09-21-2015, 08:05 AM   #36
[email protected]
Car is looking good Chase.
The mount kits for K20 DA's and EF's all seem to push the engine quite low in the engine bay. This is done to clear and close the hood.
This is something all EF and DA chassis' have to deal with.
Dropping too low does mean there is a higher risk of contact.
It doesn't help that the K engine is tall, that also affects available ground clearance.
Old 09-22-2015, 11:41 AM   #37
american.graffiti
K20a.org Basic User
american.graffiti's Avatar
Subscribed.
__________________
Thanks: Will @ Hybrid-Racing | Tim @ Hybrid-Racing | Mike @ K-Tuned | Karcepts
Vouches: Theone4dafans|1320WhtRex|GPWF20C|Mr.KDes|Katman|Go vo82|KseriesFTW|Stern|NAcivicsi
american.graffiti is offline   Reply With Quote Quick reply to this message
Old 09-24-2015, 05:07 AM   #38
[email protected]
Old 02-02-2017, 01:24 PM   #39
snoop_gee
Lifetime Member
snoop_gee's Avatar
Quote:
Originally Posted by F-BOM View Post
is the drain plug available separately?
same
__________________
.::G-ride Update::. custom metal fab bits and pieces
snoop_gee is offline   Reply With Quote Quick reply to this message
Old 11-10-2017, 10:38 AM   #40
[email protected]
Back on the forum.
Link to our K-Tuned Magnetic Drain Plug:
http://k-tuned.3dcartstores.com/Magn...lug_p_449.html
Reply
Bookmarks
Tags
k-tuned, ktuned, oil pan, pan, steel pan
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Thread Tools
Posting Rules
You may not post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
