K-Tuned 8th Gen Civic Si and RSX/EP3 Silicone Radiator Hoses - K20A.org .:. The K Series Source . Honda / Acura K20a k24a Engine Forum
Reply
Thread Tools
Old 03-28-2013, 08:02 AM   #1
[email protected]
K20a.org Master User
Default K-Tuned 8th Gen Civic Si and RSX/EP3 Silicone Radiator Hoses
MSRP: $89.99
Applications: 06-11 Civic (Si model only), 02-06 RSX (all models) and 02-05 EP3 Civic
K-Tuned 8th Gen Civic Si Silicone Radiator Hoses
K-Tuned 8th Gen Civic SI Radiator Hoses are designed as a direct replacement for your worn out and cheap factory hoses. These upgraded hoses will fit perfectly with the OEM radiator and most 8th Gen Civic SI specific aftermarket units. K-Tuned rad hoses are made from strong, heat resistant, high grade, 4-ply reinforced silicone. The inner layers of silicone are red and the outer layer is finished in black with white K-Tuned logos at each end. Many other applications are available, including hoses for the RSX/EP3 and several K-Swap vehicles with varying rad setups.
K-Tuned RSX/EP3 Silicone Radiator Hoses
K-Tuned RSX/EP3 Radiator Hoses are designed as a direct replacement for your worn out and cheap factory hoses. These upgraded hoses will fit perfectly with the OEM radiator and most RSX/EP3 specific aftermarket units. K-Tuned rad hoses are made from strong, heat resistant, high grade, 4-ply reinforced silicone. The inner layers of silicone are red and the outer layer is finished in black with white K-Tuned logos at each end. Many other applications are available, including hoses for the 8th Gen Civic Si and several K-Swap vehicles with varying rad setups.
Or email: [email protected]
K-Tuned 8th Gen Civic Si Silicone Radiator Hoses:
K-Tuned RSX/EP3 Silicone Radiator Hoses:
Mike@K-Tuned is offline   Reply With Quote Quick reply to this message
Reply
Bookmarks
Tags
civic si, ep3, rad hoses, radiator hose, rsx
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Thread Tools
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
