90 Integra turbo k20 rebuild - Page 2 - K20A.org .:. The K Series Source . Honda / Acura K20a k24a Engine Forum
Reply
Thread Tools
Old 05-29-2013, 10:36 AM   #21
[email protected]
K20a.org Basic User
Default Re: 90 Integra turbo k20 rebuild
What TB are planning to use? looks goods so far.
Rain@K-Tuned is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 06-01-2013, 04:50 AM   #22
gLok
Lifetime Member
gLok's Avatar
Have a couple small things to update on while im still waiting for my wastegate flange and wastegate to arrive. Still haven't figured out which injectors i'll be using either but once the wastegate stuff arrives i can mock up the motor in the car and get all of the piping done.
Quote:
Just going to be using a 70mm Edelbrock that i got from the guys at http://sflautosports.com
I made up a plate with a -16AN fitting for the inlet for my water pump. Not going to be using a thermostat anymore and needed the fitting to feed into the radiator.
Also shaved the oem breather off of the valve cover and added a -16AN fitting off the back of it. There's a little ramp on the inside of the valve cover so i put the fitting behind it to prevent oil from flicking off the cams and filling the breather tank. If it doesn't work i'll have to add a dam in there. The fitting came out of our spare parts bin so it's a little haggard but will work fine.
I'm just learning how to weld so it's not the prettiest thing ever
Finally gave it a coat of VHT wrinkle black to hide my welds lol.
__________________
90 Integra K20 turbo
gLok is offline   Reply With Quote Quick reply to this message
Old 06-01-2013, 07:27 AM   #23
signalpuke
K20a.org Master User
signalpuke's Avatar
__________________
[SIGPIC][/SIGPIC]
New to the K-Series? ☆★☆★ DIY and FAQ ★☆★☆ <------- CLICK THE LINK!
Otatsiihtaissiiststakio piksi makamo ta psswia
signalpuke is offline   Reply With Quote Quick reply to this message
Old 06-06-2013, 09:08 PM   #24
91_teg
New Member
what axles did you use and for the wiring any tips/ pointers????? how the guage cluster is hooked up or even who did you get the conversion harness from and the actual engine harness ?
91_teg is offline   Reply With Quote Quick reply to this message
Old 06-11-2013, 05:52 AM   #25
gLok
Lifetime Member
gLok's Avatar
Quote:
Now i'm using base model rsx axles.
I don't have a conversion harness, i just wired it all up myself using aftermarket relays for the fuel pump and ecu. I'm putting an s2000 cluster in the car this time around but still trying to find plugs for it.
__________________
Old 06-11-2013, 08:01 AM   #26
Chef Andre
Default
SO SICK!!!!
Sent from my SCH-I535 using Tapatalk 2
Chef Andre is offline   Reply With Quote Quick reply to this message
Old 06-16-2013, 12:57 PM   #27
gLok
Lifetime Member
gLok's Avatar
Quote:
Originally Posted by Chef Andre View Post
SO SICK!!!!
Thanks, sucks that it's taking so long but should be moving faster in the coming weeks.
__________________
Old 07-13-2013, 04:47 PM   #28
gLok
Lifetime Member
gLok's Avatar
Finally got motor in.
Pulled all of the front end apart to polish headlights and fit intercooler as well.
__________________
Old 07-15-2013, 11:49 PM   #29
92iNTEGS-R
K20a.org Basic User
92iNTEGS-R's Avatar
Dam that turbo looks really big so does that intake manifold.
It's a win win if you ask me.i like!
So what are you gonna do with the intercooler? I'm pretty sure
it's gonna be big, but DA's have a small front bumper.
You gonna cut?
__________________
i- VTEC-
1992 Integra GS-R stolen 2015 RIP
FA5 Si coming soon
92iNTEGS-R is offline   Reply With Quote Quick reply to this message
Old 07-16-2013, 06:04 AM   #30
gLok
Lifetime Member
gLok's Avatar
You gonna cut?
yeah im cutting most of the front metal out to fit the intercooler and radiator.
I'm not cutting the bumper cover on the outside, only behind it.
__________________
Old 07-20-2013, 12:34 AM   #31
92iNTEGS-R
K20a.org Basic User
92iNTEGS-R's Avatar
can't wait to see the fitment bro.. shhh man look at that oil pan, i knew it was bad but dang that picture is the truth
__________________
i- VTEC-
FA5 Si coming soon
Old 07-20-2013, 04:56 PM   #32
gLok
Lifetime Member
gLok's Avatar
I really wish i could raise the motor up a bit to get some ground clearance. Here's a better pic to see how little ground clearance i have.
I got the front crossmember removed so i could start fitting the intercooler.
The original plan was to do a dual backdoor setup but i think im just going to do the pass side now. Now that i see how much room there is between the alternator and intercooler, i can't do the radiator setup that i wanted and will probably just use an aftermarket Scirocco radiator or something like that.
I also started cleaning up my headlights which were looking really horrible. The plan there is to sand them down and then clear coat.
__________________
Old 07-20-2013, 09:57 PM   #33
Ricextacy
K20a.org Basic User
First da k20 turbo!? Build looks incredible. Keep it up!
Ricextacy is offline   Reply With Quote Quick reply to this message
Old 07-27-2013, 10:15 AM   #34
ChaseIntegra
K20a.org Advanced User
ChaseIntegra's Avatar
Nice Kevin! I love seeing your progress! You should do more documenting with pictures. It's useful for you to look back on and helps others in the future. Just a thought.
ChaseIntegra is offline   Reply With Quote Quick reply to this message
Old 07-31-2013, 03:26 AM   #35
gLok
Lifetime Member
gLok's Avatar
Quote:
Seems like there are a few in the works, guess we'll see who finishes first lol.
Quote:
Thanks, i try to do as much as i can but the way i work i get into a zone and forget to take pics.
__________________
Old 07-31-2013, 05:24 PM   #36
ChaseIntegra
I know exactly what you mean!
Old 08-28-2013, 10:52 PM   #37
Ricextacy
K20a.org Basic User
because race car!
Old 08-31-2013, 06:53 PM   #38
gLok
Lifetime Member
gLok's Avatar
I'm learning how to tig weld aluminum so the progress is slow. Made the intercooler mounting bracket, drivers side charge pipe and finished modifying the end tank on the intercooler.
waiting for more supplies to mount wastegate
__________________
Old 09-01-2013, 08:51 AM   #39
Ricextacy
K20a.org Basic User
thats one BIG inter-cooler! looks awesome
Old 09-01-2013, 09:28 PM   #40
92iNTEGS-R
K20a.org Basic User
92iNTEGS-R's Avatar
First i was like now im like i had to stare at it for a good min or so. I've never seen a K turbo da until now. Now all these ideals are flying around in my head lol.
__________________
i- VTEC-
FA5 Si coming soon
Reply
Bookmarks
Tags
1990, acura, integra, k20, turbo
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Thread Tools
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
