Got timing chain slap? Skunk2 does. - Page 27 - K20A.org .:. The K Series Source . Honda / Acura K20a k24a Engine Forum
Old 05-01-2012, 08:36 AM   #521
b.r.i.a.n.
b.r.i.a.n.'s Avatar
Default Re: Got timing chain slap? Skunk2 does.
Originally Posted by signalpuke View Post
More cases here, Stage 1 and 2 cams blowing up aftermarket tensioners.
https://www.k20a.org/forum/showthread.php?t=102957
lol in that case i guarantee you it's the tensioner. i had 2 customers that had hybrid tensioners go bad. one was on a set of skunk2 stage 2 version 3 and another was on a set of drag cartel cams.
i've always recommended oem honda tensioners. honda revised them again a few years ago and i've yet to have a problem with them.
2003 Civic Si - k20A2 powered - 241 whp/166 tq - sold
2002 Grand Prix White S2000 - 234 whp/155 tq - E85 powered
b.r.i.a.n. is offline   Reply With Quote Quick reply to this message
Old 05-01-2012, 08:46 AM   #522
signalpuke
signalpuke's Avatar
Doesn't matter if it is an OEM tensioner, or an aftermarket. If the cams are decent, they shouldn't be destroying them.
[SIGPIC][/SIGPIC]
New to the K-Series? ☆★☆★ DIY and FAQ ★☆★☆ <------- CLICK THE LINK!
Otatsiihtaissiiststakio piksi makamo ta psswia
signalpuke is offline   Reply With Quote Quick reply to this message
Old 05-01-2012, 09:13 AM   #523
b.r.i.a.n.
b.r.i.a.n.'s Avatar
i'm telling you it has nothing to do with the cams. the design of the hybrid tensioner just isn't all that great. they have re-designed these tensioners multiplie times.
i had another local tuner that had a hybrid tensioner go bad on a set of ips kme's.
so now you're going to tell me that ips cams aren't decent?
Old 05-01-2012, 09:23 AM   #524
signalpuke
signalpuke's Avatar
Show me a video of KMEs w/the chain slap that the Skunk2 cams exhibit.
[SIGPIC][/SIGPIC]
Old 05-01-2012, 09:31 AM   #525
signalpuke
signalpuke's Avatar
The chain slap is due to a geometry problem in the cam design. It is very simple to understand, but the implications are not.
If the lobes are off on these cams, then the cylinder/cylinder filling is different as well. This affects balance, harmonics, and cyl/cyl tolerances. It is the main reason that these cams can NOT perform on the same level as those with proper lobe design.
Ask anyone that understands how bearing clearances are spec'd for the mains, or how our of round geometry for the rotating assembly, and any other engine design criteria that is taken into account for balance and lack of frictional losses, are affected by this poor design.
I am not talking shit here to just piss off a company, and I know you are not stupid. You know there is a problem with these cams. I just want to ensure that people understand that this problem can have many consequences irregardless of what 'band-aids' they install or tune to run them.
[SIGPIC][/SIGPIC]
Old 05-01-2012, 09:51 AM   #526
b.r.i.a.n.
b.r.i.a.n.'s Avatar
again. the hybrid tensioners failing has nothing to do with the design of the cams. why is it that i never have problems with oem tensioners even with skunk2 cams?
you're just using skunk2 cams as a scapegoat. like i said previously i've seen these tensioners fail with multiple camshafts out there, not just skunk2.
Old 05-01-2012, 09:58 AM   #527
signalpuke
signalpuke's Avatar
Tell them to post it up.
This thread is about chain slap, and issues with Skunk2 cams.
If you have a problem with the Hybrid tensioners, bring it up in the other thread that is directed toward their product.
[SIGPIC][/SIGPIC]
Old 05-03-2012, 06:52 PM   #528
teamjdm239
K20a.org Advanced User
teamjdm239's Avatar
ok so heres a stupid question, just figured i'd ask after going through this whole thread, what if you use a softer/or stiffer valvespring on the exhaust side to make up for the faster closing exhaust ramps? could that be a fix?
Iphone repair & Modding xbox360's! HMU
Sold to:Bossman032,funny_guy,1320WhtRex,illonggo,texm3x, 87si n/a,TYFOMOTO/NLM,2s1owsi,CJM,David59982,Kazino42,Oscaraysco
teamjdm239 is offline   Reply With Quote Quick reply to this message
Old 05-13-2012, 12:51 PM   #529
allmotorbubble
I ran sk2 stage 3s for 2.5 seasons. Same OEM chain and tensioner. 0 problems
allmotorbubble is offline   Reply With Quote Quick reply to this message
Old 05-18-2012, 08:03 PM   #530
texm3x
texm3x's Avatar
just installed my skunk2 stage 2 v3's chain slap was issue but was resolved with a simple tune...
texm3x is offline   Reply With Quote Quick reply to this message
Old 09-18-2012, 10:14 AM   #531
gpwf20c
gpwf20c's Avatar
I'm running skunk stage 2 now with chain slap 800 miles into Re-build brand new chain,guides, and tensioner honda got code p0341. Never again skunk2 cams
gpwf20c is offline   Reply With Quote Quick reply to this message
Old 07-26-2013, 07:20 PM   #532
texm3x
texm3x's Avatar
^^ saw this last old ass post that needed attention.. resolution for next man should of preloaded tensioner and dropped low cam angle to 0* till chain slap goes away...
Old 07-26-2013, 09:55 PM   #533
signalpuke
signalpuke's Avatar
Hiding the problem isn't the solution.
[SIGPIC][/SIGPIC]
chain, chain slap, chain tensioner, junk2, skunk2, tensioner, worn cam
