K20a with automatic transmission - K20A.org .:. The K Series Source . Honda / Acura K20a k24a Engine Forum
Old 08-18-2010, 02:51 AM   #1
Tiger_
Default K20a with automatic transmission
From this link, I got an idea to put K20a with automatic transmission.
I talk to babyk for a while and decided to do.
K20a block
My old automatic gear box.
K20a block and gearbox before build up and after.
Tiger_ is offline   Reply With Quote Quick reply to this message
Old 08-18-2010, 03:03 AM   #2
Tiger_
Default Re: K20a with automatic transmission
Everythings perfect fit
Except this
But no problem. Cut off a little bit for perfect fitting.
Old 08-18-2010, 03:07 AM   #3
Tiger_
I use the original ECU with automatic transmission and reflash with Civic typeR's fuel map via Hondata FlashPro.
thanks to babyk for tunning.
Old 08-18-2010, 03:25 AM   #4
KidnKorner
Banned
KidnKorner's Avatar
2007+ K20A, did you get a deal on the engine?
KidnKorner is offline   Reply With Quote Quick reply to this message
Old 08-18-2010, 06:48 AM   #5
Tiger_
K20a and K20z2 have different only inside the block.
I think all K20 have the same outside block.
Old 08-18-2010, 10:11 AM   #6
IAciv
IAciv's Avatar
Interesting. What chassis did you put this in and are you going to dyno it to see how much hp it makes with the auto?
Form=Function
IAciv is offline   Reply With Quote Quick reply to this message
Old 08-18-2010, 10:16 AM   #7
Brandon Heat
K20a.org Advanced User
Brandon Heat's Avatar
did you dyno it?
Brandon Heat is offline   Reply With Quote Quick reply to this message
Old 08-18-2010, 04:11 PM   #8
Tiger_
My 2006 civic (FD) come with K20z2 and automatic transmission.
Originally Posted by Brandon Heat View Post
did you dyno it?
Coming soon. Nearest is 600 km from here.
Next trip to Bangkok, I will go to dyno.
2006 civic FD1, K20z2 engine, Automatic transmission with paddle shift.
Old 08-18-2010, 09:25 PM   #9
Mixwell
k20a.orgy
Mixwell's Avatar
.........................issforged wheels.........................
=====>MIXWELL'S s2k24a2 PROJECT<=====
Mixwell is offline   Reply With Quote Quick reply to this message
Old 08-18-2010, 10:45 PM   #10
EG6VtecR
Nice imagine a 4 door DC with that set up
Bought from: tommylee559 onefstek locash Marc P synapse motorsport 1qwikef marc15skate Torukucams vtec718 hndarcr
Sold to: rsxmatt1985 vtec718 bestofbest SCAMMER: doctordc5
EG6VtecR is offline   Reply With Quote Quick reply to this message
Old 08-18-2010, 11:09 PM   #11
KidnKorner
Banned
KidnKorner's Avatar
Z2 is VERY similar to A3 in power as I recall. Doesn't the Canadian base Acura CSX come with a Z2?
Old 08-18-2010, 11:52 PM   #12
JDMEG6
JDMEG6's Avatar
Yup the csx comes with the z2 it's almost identical power to an a3. My buddy has one till I looked into it I always thought it was a A3.
K24A4 Pistons/Rods+Bearings (still assembled)
Make Offer
Old Setup, awaiting new times
[email protected]/
[email protected] mph
best MPH 110.021...116.961
JDMEG6 is offline   Reply With Quote Quick reply to this message
Old 08-18-2010, 11:58 PM   #13
KidnKorner
Banned
KidnKorner's Avatar
Information about the Z2 is not as widespread as an A3, I'm curious to know if it is a 2 lobe rocker like the A3 like an i-VTEC-E?
Old 08-19-2010, 12:36 AM   #14
11248c
Banned
11248c's Avatar
NICE
11248c is offline   Reply With Quote Quick reply to this message
Old 08-19-2010, 01:17 AM   #15
Tiger_
Parts moved from z2.
- All pulleys and belt. (K20a use oil power steering, K20z2 use EPS)
- EGR valve
- K20z2 harness
K20a's parts use.
- All sensors. Some sensors have different plug, modify them.
- Water pump.
- IM and TB
- Generator (K20a use 55A, K20z2 use 45A)
Must do.
- Transmission Oil Cooler
- New header. (K20a's header hit to EPS motor)
Old 08-25-2010, 08:23 AM   #16
babyk
stay tune for this car's tuning
i was damn busy in Europe recently
Malaysia Honda Civic Club @ http://www.my-civic.com
babyk is offline   Reply With Quote Quick reply to this message
automatic, k20a, transmission
