Vorhizzle's 1993 Hatch - K20A.org .:. The K Series Source . Honda / Acura K20a k24a Engine Forum
Old 03-31-2013, 06:27 PM   #1
Vorhizzle
Vorhizzle's Avatar
Default Vorhizzle's 1993 Hatch
I know I posted some pictures of a sedan I was tinkering on but I decided to go with a hatch and had that thread deleted. With that being said here is the build up.
Here is the car how I got it.
It looked pretty straight when I bought it but the more I looked at it the more I decided it needed body work and paint. So I took it to a local shop and they treated me pretty good.
I bought a carbon fiber hood that had already been cleared and used.. the threw an idea out there about some black stripes to follow the bodylines of the car and I told them to give it a shot.
Here is a few shots of the finished product.
Here are my engine and trans k20a2 and 08 SI trans
Today I installed the Tuff Trac baffle.. pretty easy here are some pics.
Also did some fitment tests on my JDM Integra Type r Hubs and Spindles with my USDM rims.. I'd say they fit..
I need to take more pics of the parts I've got I forgot to today but the car will be receiving quite a bit of work over the next few weeks and hopefully she will be on the street in no time.
EDIT: I forgot to add that it looks like a monster truck because I have my AMR Engineering coilovers lifted so the body guys would have an easier time.
Hatch
Colorall Technologies
Wagon
Vorhizzle is offline   Reply With Quote Quick reply to this message
Old 03-31-2013, 07:57 PM   #2
type-Spaz
K20a.org Advanced User
Default Re: Vorhizzle's 1993 Hatch
love that color!
Real nice oil baffle setup
type-Spaz is offline   Reply With Quote Quick reply to this message
Old 03-31-2013, 09:11 PM   #3
Vorhizzle
Vorhizzle's Avatar
Thanks, I figured you can't go wrong with teal.
Hatch
Wagon
Old 03-31-2013, 11:28 PM   #4
gtimportfanatic
gtimportfanatic's Avatar
very nice .. just a basic bolt on build?
| SoHonda Garage Token.
| SHG_Blog | SHG_Web
gtimportfanatic is offline   Reply With Quote Quick reply to this message
Old 04-01-2013, 06:27 AM   #5
Vorhizzle
Vorhizzle's Avatar
Yea pretty much a basic build for now.. I want to be able to drive it this summer, this coming winter I will actually build a motor still on the fence on which one though
Hatch
Wagon
Old 04-01-2013, 09:41 AM   #6
bodyman
Looks nice man! I love that teal color when its all fresh. keep working haha
bodyman is offline   Reply With Quote Quick reply to this message
Old 04-01-2013, 10:39 AM   #7
Vorhizzle
Vorhizzle's Avatar
Thanks man I forgot to take a picture of the pile of parts I have from you. The baffle went on nice and easy.
Hatch
Wagon
Old 04-01-2013, 10:55 AM   #8
Orthow
Orthow's Avatar
I'll be the first to say it: They should have left the hood alone OR color matched it to the car. Looks like someone took electrical tape to the hood.
Car looks great other then that though.
Orthow is offline   Reply With Quote Quick reply to this message
Old 04-01-2013, 11:15 AM   #9
Vorhizzle
Vorhizzle's Avatar
You know in the pics it doesn't look to great but in person i like it you can still see the carbon fiber through it and once i get the black wheels on it i personally think it'll look pretty good. Each to their own.
Hatch
Wagon
Old 04-01-2013, 02:15 PM   #10
bodyman
lug nuts work out ok?
Old 04-01-2013, 02:44 PM   #11
Vorhizzle
Vorhizzle's Avatar
I don't know yet, I haven't got the type r spindles on the car yet. Waiting to put it on the lift until I go and buy some tires for my rims. Knowing my luck I'd put this car on the lift and my sister's water pump would explode or something.
Hatch
Wagon
Old 04-02-2013, 03:24 PM   #12
Vorhizzle
Vorhizzle's Avatar
Small update some pics of the parts I have lined up.
Insane Shafts 36mm Axles
I installed some extended studs onto my JDM rear trailing arms. Waiting to press bearings and do the same on the fronts.
Wiring Harness, Half Shaft, Clutch, Clutch Cables
New starter and alternator
Type R LSD
New Integra front lower control arms with sway bar links. (Integra R sway bar on the way from Bodyman)
RSX K tuned shifter, Emtech springs, New slave cylinder, intake gaskets, 4040 prop valve, 70mm throttle boddy, Integra RS Brake booster and master cylinder, Box of bolts from Bodyman. Integra R calipers waiting for paint.
Now I am due to put in some work this weekend.
Hatch
Wagon
Old 04-05-2013, 11:44 AM   #13
[email protected]
Paint and bodywork look great.
Subscribed to watch you build this.
Mike@K-Tuned is offline   Reply With Quote Quick reply to this message
Old 04-05-2013, 03:16 PM   #14
bodyman
In for an update!
Old 04-05-2013, 07:25 PM   #15
Vorhizzle
Vorhizzle's Avatar
Should be putting in quite a bit of work on Sunday/Monday since I got let go from my job right when I got the car back from paint.. Been trying to find a new one like crazy
Hatch
Wagon
Old 04-08-2013, 08:20 PM   #16
Vorhizzle
Vorhizzle's Avatar
Update as promised
Got some goodies from bodyman today..
New shift knob and ITR shift boot
ITR front sway bar
OEM mud flaps
Put my rear sway bar, sub frame brace and lower control arms on.
Also pulled the D15Z1 out of this VERY carefully planning on putting it in my wagon.
Never been more sketched out working on a car as I was with this.
Going to start cleaning up the bay soon.
Hatch
Wagon
Old 04-08-2013, 10:54 PM   #17
turbocx
turbocx's Avatar
Awesome build man. We have similar setups. I did the k20a2 swap in my EG and I have the JDM 5 lug conversion with USDM type R wheels that I'm going to be putting on as soon as it warms up here. Your suspension set up is nice man, this is exactly how i plan on building my hatch. Good choice in parts
turbocx is offline   Reply With Quote Quick reply to this message
Old 04-09-2013, 03:16 PM   #18
Vorhizzle
Vorhizzle's Avatar
Thanks... Small update
Got motor mounts (Hasports) and shifter plate today.
Hatch
Wagon
Old 04-09-2013, 09:18 PM   #19
gtimportfanatic
nice updates! i have the same shift knob in my EP3! it's awesome. in for more progress
| SHG_Blog | SHG_Web
Old 04-15-2013, 08:21 PM   #20
Vorhizzle
Vorhizzle's Avatar
Started stripping down the bay today, got most of the stuff removed but forgot to take a picture of the passenger side motor mount removal. Here are a couple of pics.
Hatch
Wagon
