S2000 push button start...dash install - K20A.org .:. The K Series Source . Honda / Acura K20a k24a Engine Forum
Go Back   K20A.org .:. The K Series Source . Honda / Acura K20a k24a Engine Forum > K-Series Technical Forum > NEW - Welding and Fabrication Forum
Reply
Thread Tools
Old 12-30-2011, 10:50 AM   #1
BlackNDecker
[cool slogan goes here]
BlackNDecker's Avatar
Default S2000 push button start...dash install
At the risk of coming off like "Johnny half project" with all my other ongoing projects, I wanted to share another project I'm working on.
This will be a S2000 install into a 2001-2005 civic center console. I deleted the climate controls so I will be installing some gauges and a push start on the left hand side. The top vents and lower 3 holes will be "deleted" with fiberglass...the hazard button will remain in the same spot:
These three holes will be glassed over:
I bought some Stack electric gauges...oil pressure and water temp...that will be placed in the top two holes. The push button start will go in the lower hole:
The Bondo "bumper repair kit" has the absolute best plastic epoxy I have ever used...this shit absolutely will not let go. I got the push button start for like $35 bucks online (sorry Ryan, I should have bought from you). My dumb luck, I happened to find a piece of black plastic pipe that fits the push button start like virgin puss and it also has a lip that will allow me to epoxy it to the center console. The wire mesh will be cut into strips to reinforce the epoxy.
This is a rough idea how the start button will look:
I sanded the bonding areas with 40 grit sand paper so the epoxy could really bite into the plastic...then got to work:
And I had to whore this pic out again...the center console will sit in my custom carbon fiber dash...the vents were also deleted from the dash:
After the epoxy dried:
And here is how I will mold the front....felt is stretched across the surface:
And then I will brush resin across the surface:
I'm just waiting on the gauges because I need to see how much I will have to modify the center console to get them to fit before I start glassing it. That is all for the weekend.[/quote]
Gauges arrived and got them set in the dash panel:
Couldn't get any closer:
And wrapped in felt ready for resin:
I'm gonna do a little more shaping...I'd like to have a small even gap between the gauges.
I got the resin brushed on and it's curing. The center area was left 'soft' so that i could shape it for placement of a double din touch screen. Up next will be sanding and reinforcing.
Decided just to forge ahead tonight...laid down some reinforcement fiberglass and got the gauges mounted:
And a tiny bit more space between the gauges:
After some more shaping...it still needs surfacing with a filler to smooth the surface:
And an idea of what it will look like...all the vents have been deleted now as if from the factory:
Got the panel sanded and primed...now comes the hardest part, filling in all the pin holes. This is the part that can make or break a piece...it will either look good at 10" or 10' depending on how much time is spent.
I can finally bring some closure to this thread.
I used some Bondo "red glazing compound" and sanded that smooth then used black Plasti-kote to finish it...there are one or two very small imperfections (I was too lazy to apply a third coat of Bondo...again, not trying to make a show car):
With the gauges installed:
And installed in the dash:
Ok fellas, the wiring is all finished and the s2k starter works like a charm....here are some pics:
It turned out perfect...I recommend this mod to anyone
__________________
Fuck JDM....innovate USDM
| ***** YOUR COMPANY HERE *****
| ** CONTACT ME FOR AFFORDABLE **
| ****** ADVERTISING RATES *****
BlackNDecker is online now   Reply With Quote
Sponsored Links
Advertisement
Old 12-30-2011, 11:20 AM   #2
crdizzle6288
K20a.org Master User
crdizzle6288's Avatar
Default Re: S2000 push button start...dash install
good start. im in for updates and cant wait to c the finished product.
__________________
TOP SETUP
crdizzle6288 is offline   Reply With Quote
Old 12-30-2011, 12:17 PM   #3
BlackNDecker
I'm still waiting on the gauges...hopefully they'll come in Tuesday (damn holiday weekends).
In the meantime here are some pics:
For the face of the center console, I'm gonna stretch a piece of felt and brush it with resin. This will form the basic shape of the face plate...it will later get reinforced and sanded smooth. This is the technique most people use to make speakerboxxxes.
__________________
Old 12-30-2011, 12:20 PM   #4
BlackNDecker
__________________
Old 12-30-2011, 12:30 PM   #5
crdizzle6288
who did the carbon fiber on the dash? looks pretty bad ass.
__________________
TOP SETUP
Old 12-30-2011, 01:43 PM   #6
hybrid racing
K20A.org Sponsor
hybrid racing's Avatar
The dash does look pretty awesome!
__________________
When you purchase a Hybrid Racing product you help support NEW AND INNOVATIVE K series products to make your swap easier and your car faster.
Here are just 5 of those products: AC Kits & Bolt in shift box & Chain Tensioner & PS Kits & 05-06 Speed Converter
KSWAP PARTS LIST Email us sales@hybrid-racing.com
TAKE THE HR SURVEY AND WIN $250
HR Facebook
Quote:
Originally Posted by EGhatchNJ View Post
hybrid racing
you guys are seriously always doing big things... thats why im running all your products in my car
my project will be put on hold for this bolt in shifter box so i dont have to go cutting my exhaust tunnel up
hybrid racing is offline   Reply With Quote
Old 12-30-2011, 02:18 PM   #7
BlackNDecker
Thanks guys
__________________
Old 12-30-2011, 04:11 PM   #8
bodyman
K20A.org Sponsor
bodyman's Avatar
This looks like fun, and that dash is sick!! Suscribed to this thread, and you know where to find me when you want deals
bodyman is offline   Reply With Quote
Old 12-30-2011, 04:50 PM   #9
BlackNDecker
Quote:
Let me know when you wanna get yours done...I have one more black plastic tube.
__________________
Old 12-30-2011, 04:54 PM   #10
Boosted-eh-804
K20a.org Advanced User
Boosted-eh-804's Avatar
Oh this is sick. That dash is killer
__________________
RCautoworks
Vouches- D-Rock,Murrdog9000,oscarsayco,joeman182
Boosted-eh-804 is offline   Reply With Quote
Old 12-30-2011, 06:35 PM   #11
bodyman
K20A.org Sponsor
bodyman's Avatar
Quote:
I have a RSX dash with ITR button holder, not as cool as this, thanks though
Old 12-30-2011, 06:42 PM   #12
BlackNDecker
No way man, full RSX dash swap is the shiz. Are you swapping the door panels as well? I've only seen one other guy with swapped RSX door panels in a 7thgen....make that two, the guy from Thailand who posted his red 4 door with complete Type R interior. Did you ever see that build on here?
__________________
Old 12-31-2011, 03:19 AM   #13
bodyman
K20A.org Sponsor
bodyman's Avatar
I am am gonna try the door panels to ,I know they will need cut though, if I can find a cheap set to hack. Em2 door panels brand new are cheap ,that's the only thing that's got me wanting to just not those in, wait and see. Get this piece done ,what are you gonna paint it with?
Old 12-31-2011, 03:24 AM   #14
bodyman
K20A.org Sponsor
bodyman's Avatar
Something to think about,since that piece is made fit snug in there, you are adding the size around the outside of it the thinkness of the cloth and resin, it might not fit after your done, maybe you should grind 1/16" off the edge all the way around the put the cloth back on and do it, then perfect size
Old 12-31-2011, 03:31 AM   #15
gmundz87
In for more updates.. looks killer!
gmundz87 is offline   Reply With Quote
Old 12-31-2011, 07:42 AM   #16
BlackNDecker
The guy on 7thgenhonda who got the RSX door panels to work never revealed how he did it....bastard
As far as the finish on the center panel, I'm thinking it might be too much carbon fiber if I had it covered like the dash....that's why I'm considering just painting it satin black like the rest of the dash. I'm also thinking about covering it with "brushed aluminum" vinyl.
__________________
Old 12-31-2011, 09:28 AM   #17
Boosted-eh-804
The brushed alum would be a nice touch and some contrast to all the CF. I vote to do it!
__________________
RCautoworks
Old 12-31-2011, 06:28 PM   #18
BlackNDecker
This stuff is pretty sweet....I would love to get a whole car wrapped in brushed aluminum vinyl...unfortunately it would be more expensive than paint.
__________________
Old 12-31-2011, 07:19 PM   #19
preston
Lifetime Member
preston's Avatar
sick stuff Brian! can't wait to see this done, and in person someday
__________________
Vouches:
Scott@HPT, K-serious-Eg, 93civichb, eg6k20a2, ReDeMoN, JDMciv'bomb, Clean EH2, Bodyman, BlackNDecker, mr fobster, filipinop1405, importracer2123, 1320whtrex, justtheshop, negrok20r, rexthermal, darqnez, Acurazor, Dube Built.
K24/K20 rebuild in progress
preston is offline   Reply With Quote
Old 01-03-2012, 09:14 AM   #20
BlackNDecker
__________________
Reply
Bookmarks
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.0
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
