cheapest place to buy k-tuned iacv rotator from? - K20A.org .:. The K Series Source . Honda / Acura K20a k24a Engine Forum
Reply
Thread Tools
Old 12-20-2011, 03:40 AM   #1
exquisit
K20a.org Basic User
Default cheapest place to buy k-tuned iacv rotator from?
looking to get one and postage to aus is nearly as much as the item itself!!!
any cheap places anyone know of?
exquisit is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 12-20-2011, 03:42 AM   #2
Mr. KDes
P.M.W./A.W.S.
Mr. KDes's Avatar
Default Re: cheapest place to buy k-tuned iacv rotator from?
Here. Saved you some money.
Karcepts
Quote:
Originally Posted by Karcepts View Post
BTW, for those of you who desire to retain your IACV and want to avoid clearance issues on your RBC setups, there is a simple and FREE mod that does not require purchasing a custom rotation plate to do the job.
*FREE IACV Rotation Information*
Non-rotated IACV:
Non-rotated IACV:
Un-bolt IACV, rotate 180 degrees, re-bolt to throttle body:
Connect the coolant passage nipples with a hose. Make sure all coolant is flushed prior to installing the hose. The hose in this instance will no longer be used for coolant passage, but will act as an air passage to re-allow the IACV to function when rotated 180 degrees (study the porting within the IACV and the new position with the hose passageway and you will see the logic):
Loop the coolant passages on the block:
Fully functioning IACV rotated 180 degrees:
Enjoy:
__________________
WestSPEC™
Quote:
Originally Posted by Adam West View Post
It LIVEEEEESSSSSSSSSSS!
Mr. KDes is offline   Reply With Quote Quick reply to this message
Old 12-20-2011, 03:48 AM   #3
exquisit
K20a.org Basic User
u my friend... are a fukin champion!!!
coolant hoses have already been d/c so this is easy to do!
thanks so much once again!
Old 12-20-2011, 04:00 AM   #4
Mr. KDes
P.M.W./A.W.S.
Mr. KDes's Avatar
No problem at all.
Brian from Karcepts is here to help out guys like you.
__________________
WestSPEC™
Old 12-20-2011, 05:30 AM   #5
John@K-Tuned
K20A.org Sponsor
John@K-Tuned's Avatar
Depending on what manifold you have this will not work because the plug gets in the way, we found this out when we designed our part. But if it works on your setup its a score.
__________________
Proud K20a.org sponsor!
K-Tuned.com
John@K-Tuned is offline   Reply With Quote Quick reply to this message
Old 12-21-2011, 01:37 AM   #6
exquisit
K20a.org Basic User
yea i got an rbc so it should work
thanks once again
Old 01-12-2012, 01:50 AM   #7
exquisit
K20a.org Basic User
just an update
the switcharoo worked a treat... only problem i have now (well happened since i looped the tb water lines before this mod) is that when cruising to a stop in neutral, it has a really low idle... only concern of mine is the reallly low oil pressure that happens as a result
roughly 8psi or 0.5bar
only difference from before the switch is that now it idles low on cold... but its summer her so no probs yet
how would you guys suggest i fix the low idle in neutral and low idle when cold?
thanks
Old 01-12-2012, 08:18 AM   #8
kr4win
Lifetime Member
kr4win's Avatar
Default
In kpro
__________________
WWW.DEFCON-RACING.COM
OptionOptionJDM
WWW.OPTIONJDM.COM
kr4win is offline   Reply With Quote Quick reply to this message
Old 01-12-2012, 11:03 AM   #9
ohsnapzafingcu
K20a.org Basic User
i have a 74mm HR tb, and a RBC this mod should work too won't it?
__________________
VOUCHES: JCRasta,oscarsayco
ohsnapzafingcu is offline   Reply With Quote Quick reply to this message
Old 01-14-2012, 01:53 PM   #10
exquisit
K20a.org Basic User
thanks ... i'll have a look into it!
Old 12-23-2012, 08:35 PM   #11
bukydc5
New Member
bukydc5's Avatar
bump!!!!!!!!!!!!!!!!!!!!!!!!!
whooooo saved myself some $$$$$
cars on e hahahaha
__________________
My iVtec goes bbBBaaahhahahahAaaaAAaaa
em1 k20z3
bukydc5 is offline   Reply With Quote Quick reply to this message
Old 12-26-2012, 12:40 AM   #12
saint_
New Member
What exactly does this do?
Can I do this to my k24a4?
saint_ is offline   Reply With Quote Quick reply to this message
Old 12-26-2012, 01:27 AM   #13
richi
New Member
i did that mod too and found a way how you can do it with ANY manifold.
just take a look at the pics in the german forum where i published my swap-project.
http://www.hondapower.de/forum/showt...l=1#post227018
richi is offline   Reply With Quote Quick reply to this message
Old 12-26-2012, 09:17 AM   #14
crip
Lifetime Member
crip's Avatar
some ppl after doing swaps have issues with iacv being to close to radiator so this mod will move plug to oppisite side. depends on setup/mounts/chassis if you need to do it.
__________________
SOLD TO:iboyma, donsep3, honda_12v, allmotorbubble, Nitro1018, ZAKE, alex_KS, Db2K, shattamac, spoonhacked, richir587, datdude814, FlacoNAEG, michalo187, youhan23, valerio123, 7800rpmlaunch, screech, miaep3, 1320whtrex, asnstyle22, rvf35nc, sictegboi3, 828DC5. BOUGHTFROM: josh2man, kid, ek9-10, stRoKeD, xbigpitax, ohsnapzfingcu, mountainK, ctechone01, jpax, kadamski5140, i-vtec-eg, mo_spec, chefandre, sik20, cjm, mlotz29, yeven_stas, REALDEAL, KDub-ZeroEG, jchetty, 2.4L ef, nine2fivek20, blankyjet TRADED WITH: Acurazor, rsxmatt1985 VOUCHES: josolanes, sik20, flipsx3, noobiemcnooberson, BMFC
crip is offline   Reply With Quote Quick reply to this message
Old 02-11-2013, 04:06 PM   #15
torres21
K20a.org Basic User
Greatttt !!!!! I was having problems with the rbc on my Ep3!!! Thanksss
torres21 is offline   Reply With Quote Quick reply to this message
Old 02-13-2013, 08:06 AM   #16
bukydc5
New Member
bukydc5's Avatar
works just fine, hot weather cold weather bump for a good thread
__________________
em1 k20z3
Reply
Bookmarks
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
Thread Tools
Posting Rules
You may not post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
