gt35r k20 swapped em2 build - K20A.org .:. The K Series Source . Honda / Acura K20a k24a Engine Forum
Reply
Thread Tools
Old 09-28-2011, 09:12 AM   #1
aznskaterboy
New Member
aznskaterboy's Avatar
Default gt35r k20 swapped em2 build
Here is the updated version of my k20 turbo build thread.
Its a 2001 Civic LX 2dr Coupe, motor being swapped is a k20a2 from the rsx-s. For the turbo I went with a gt35r kit from peakboost, luckily I got my kit before the company went bankrupt and left a shit ton of people out of money and parts.
I am in the military and I am constantly doing training or some type of other bs. Between that and deployments to iraq, it makes it somewhat difficult to finish this build in a timely manner so deal with me on that one. I started this build on my two week leave from Iraq back in 2008..
Motor/Swap Parts:
HONDATA Kpro
ARP Headstuds
RBC Intake Manifold
SAMCO Radiator Hose Kit
KOYO OEM RSX Radiator
Hasport ESK1 Mounts
RSX Intermediate Shaft
RSX Clutch Lines
RSX Throttle Cable
Hondata Intake Manifold Gasket
Karcepts AC & PS Removal Kit
Greddy Oil Catch Can
PLX Wideband
Fuel System:
Walbro 255lph pump
Precision 1000cc Injectors w/ clips
Hybrid racing K-Series Fuel Rail
Aeromotive Pressure Regulator
Marshall Fuel Press Gauge
Gates Submersible Fuel Hose
Honda Resistor Box
Lots of fittings from Jegs for the fuel system
Transmission:
Driveshaft Shop Level 3.9 Axles
Competition Clutch Stage 5
Competition Clutch Flywheel
Turbo Parts:
Peakboost GT35R Turbo Kit
HONDATA Boost Control Solenoid
HONDATA 4 Bar MAP Sensor
Buddy Club Secu Turbo Timer
Summit Vaccum Hose
BLOX Vaccum Block
Gauges:
Prosport 52mm Premium Gauges
- Oil Temp
- Oil Press
- Fuel Press
- Water Temp
- Boost
Prosport Oil Filter Sandwich Adaptor for Oil Temp & Press
Accesories:
Honda Red Valve Cover
Technika CF Plug Wire Cover
Corsport Aluminum Shifter Bushings
NRG Hood Dampers
RSX-S Gauge Cluster
Strutking Pedals
Autopower Bolt-in Cage
Sparco Fighter Seat
Sparco Speed Seat
New Motor, wrapped up all pretty...
Blox Vacuum Block
Bolts and such for Sparco Harnesses
Vacuum Lines
Hondata Boost Control Solenoid
Hondata ECU
Very important part, Air Freshner lol
CF Engine Goodies
Tow hooks which I didnt end up using so I sold them.
Same thing with this Boost Controller...
Hood Dampers
Strut King Pedal Sets
Rsx-S Cluster
Resister Box for Injectors
Buddy Club Secu Timer (Turbo Timer)
with Competition Clutch lightweight flywheel
Headstuds which I havnt gotten around to install yet
Shifter Base Bushings from Corsport
Fuel Lines & Fittings from Jegs
Prosport Gauges, Boost, Water, Oil temp, Oil Press
Oil sandwich adapter
Hybrid Racing Fuel Rail
Walbro 255lph Fuel Pump
Aeromotive FPR
Subframe
Clutch Lines and Throttle Cable
RBC Intake Manifold with Karcepts Adapter Plate
Type R Valve Cover
Drive Shaft Shop Level 3.9 Axles
Lug Nuts, Studs, Radiator Hoses, Catch Can
Hasport Motor Mounts
Karcepts AC & PS Delete Kit
RSX Radiator
__________________
aznskaterboy is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 09-28-2011, 09:13 AM   #2
aznskaterboy
New Member
Default Re: gt35r k20 swapped em2 build
I started some of the build during my two weeks of R&R leave from Iraq. This is what I came home too. I think this was around June 2008.
ta-dah!
Engine Bay before the swap
Pile of parts/crap in the garage
New Motor, k20a2
Starting to install RBC, AC&PS Delet, Valve Cover
Then I installed the cage
Old Nitrous setup
and then the seats...
Then I had to go back to Iraq...
Once I got back from Iraq, I finally got to start my swap. ~ February 2009
Starting to dissasemble
My friend let me borrow his hoist.
and boom, engine is out!
Empty Engine Bay
goodbye single cam...
side by side, the D series looks so tiny...
more crap starting to clutter the garage
Had to do sime modifying to the wiring harness, it was a pain in the ass...
flywheel action!
It was late at night and my friends took off for the day. So I took apart the fuel system and started all that goodnes...
The next day we dropped the k20 into the bay.
Then fitted the Radiator
Mounted FPR and ran all the fuel lines aswell
Axles are in
Hood dampers installed
Ran all the wiring and installed my gauges as well
My awesome trunk setup lol
Got my bumpers back from getting painted
But then my leave came to an end. I had done all I could do with the parts that I had, and I had to get back up to WA. So I loaded everything up, and strapped the civic on a uhaul and started my roadtrip.
__________________
Old 09-28-2011, 09:13 AM   #3
aznskaterboy
New Member
A few weeks after I got back up to WA the turbo goods finally showed up.
3" downpipe, this thing is massive
wastegate dump tube
gt35r
better picture for size comparison
intercooler piping for the rsx, which i had to modify to fit the em2
somehow i ended up with the wrong intercooler at first, but PWR fixed the problem and sent me the right one.
This was before I had a house in WA and I was living in the Army barracks. So i had no garage, and if you have ever been to WA you know that it is constantly raining up there so my chance to work on the car everyday was pretty slim. Waited for a decent day, then went outside and started installing some parts.
Intercooler and piping wouldnt fit behind the stock bumper. Had to get rid of my foglights which I just installed a couple months ago. Took out the trusty angle grinder and got to work... in my kitchen lol.
Still needs a little work but its a start.
Then my friend was nice enough to let me borrow his garage, so i could tap my oil pan. You can see the beatiful WA weather outside...
Oil pan out, dont have any pictures of the finished product. It was around 2 am when I got done and i didnt give a shit about taking pictures at that point.
Also installed my hood pins while i was there.
One of my friends supras.
and another 2jz for the datsun that they have sitting outside...
and their other supra(1jz in this one) i guess he didnt tighten the lug nuts all the way and his wheel came off while driving down the street.
Got my exhaust piping welded together. I love the sleeper look of the vibrant muffler
Got the intercooler piping adjusted to fit. Dont mind the ugly welds, I had a friend hook me up and fixed them afterwards. They look 100% better now.
I definitely need sides and a rear lip to balance everything out. Look goofy with just the front lip. That front lip broke probably a week after that picture, shitty plastic one. So i got a poly lip afterwards and have had no problems with that one.
Then I started this never ending tuning process.
I was having problems with my O2 sensor not reading anything. After weeks of troubleshooting I gave up and just bought a PLX Wideband to bypass the stock unit. Then I figured out I had the pinout diagram backwards and had the stock sensor installed in the wrong plug lol.
After the O2 sensor issue, I was having cam angle problems. So i needed to get a new VTC solenoid. But at this point I was about to deploy again so I had to pack everything up and put my car back into storage.
I had a video of it up on my youtube but I swapped accounts and the video is gone. Trying to re-upload on this shitty internet out here is impossible so ill wait to post some better ones up when I get back.
Last picture before storage. I got the 5zigen fn01rc off a fellow 7thgen member up here in WA, he was letting them go for cheap. The intercooler piping has been painted black too, so no more silver stripe on that either.
Then I went back to Iraq, again....
__________________
Old 09-28-2011, 09:15 AM   #4
aznskaterboy
New Member
My tour in Iraq is coming to an end so its time to get this thing started again. I already ordered the VTC Solenoid and that will be at home waiting for me when I get back. I also ordered some new tires for the 5zigen's.
I got some more plans for the car but for now I just want to get her up and running for daily use.
__________________
Old 09-28-2011, 04:53 PM   #5
bodyman
K20A.org Sponsor
bodyman's Avatar
wow man! nice to see another Em2 stepping up!! That is one super clean motor/trans, you got a good one very very nice coupe
bodyman is offline   Reply With Quote Quick reply to this message
Old 09-28-2011, 05:22 PM   #6
Boostntofu
New Member
Nice build man, Seen someone was wearing a KU hat. Rock on you from kansas?
__________________
I've been blessed with many things in this life - an arm like a damn rocket, a cock like a Burmese python and the mind of a f*&kin' scientist.
Boostntofu is offline   Reply With Quote Quick reply to this message
Old 09-28-2011, 09:10 PM   #7
preston
Lifetime Member
preston's Avatar
wow dude, that was an intense build thread. i really like what you did with the car. really on point! can't wait to see the final numbers when it's done. that is gnarly! car looks really good
__________________
Vouches:
Scott@HPT, K-serious-Eg, 93civichb, eg6k20a2, ReDeMoN, JDMciv'bomb, Clean EH2, Bodyman, BlackNDecker, mr fobster, filipinop1405, importracer2123, 1320whtrex, justtheshop, negrok20r, rexthermal, darqnez, Acurazor, Dube Built.
http://www.hybrid-racing.com/
http://donkeypowerinjection.com/
http://afhkparts.com/
http://wire-worx.com/
preston is offline   Reply With Quote Quick reply to this message
Old 09-28-2011, 09:40 PM   #8
davidk20ek4
K20a.org Master User
davidk20ek4's Avatar
Damn dude car looks dope... I love in Washington also... About 1hr south from Tacoma... I have a k20 turbo Ek ... There are a few k swapped cars down here... We might have to meet up when u get back.. Get a few k20a.org Washington members and go for a drive
__________________
EVERYTHING WE DO .... WE DO IT BIG.....K-SQUAD
davidk20ek4 is offline   Reply With Quote Quick reply to this message
Old 09-29-2011, 04:03 AM   #9
munster
New Member
Car looks super good, man. I'm doing a 35R K20a2 in my EK right now.
munster is offline   Reply With Quote Quick reply to this message
Old 09-29-2011, 04:43 AM   #10
aznskaterboy
New Member
Quote:
Thanks man, I just saw your build too. Cant wait to see yours come together!
Quote:
Thats my friend wearing the hat. Im originally from KCMO.
Quote:
Thanks! I cant wait to get this thing finished and see the numbers myself!
Quote:
Awesome, well definitely have to meet up when I get up and running. Ill be coming back from Iraq in about two weeks. Is there a WA regional forum on here?
Quote:
That should be a beast! I cant imagine the same power in that little chassis
__________________
Old 09-29-2011, 05:07 AM   #11
Blazed
W E S T S P E C
Blazed's Avatar
Very nice build! Be safe out there.
Blazed is offline   Reply With Quote Quick reply to this message
Old 09-29-2011, 05:10 AM   #12
1320WhtRex
K20a.org Bounty Hunter
1320WhtRex's Avatar
Clean and done right Keep it up sir.. Not a fan of EM2's but really digging this one.
__________________
IF YOUR FS THREAD IS
NOT IN COMPLIANCE WITH THE RULES IN THE LINK BELOW, I WILL LOCK AND/OR DELETE THE THREAD WITHOUT NOTIFICATION. THANKS
FOR SALE RULES
10.1@148
Quote:
Originally Posted by Murrdog9000 View Post
...K series turbo.... not for the cheap
Vouches and Feedback Thread ,
My EF Kswap Turbo Build Thread
R.I.P. Jose Rodriguez, Robert Mercado Jr.... We'll miss you forever... Gone but not forgotten
1320WhtRex is offline   Reply With Quote Quick reply to this message
Old 09-29-2011, 05:17 AM   #13
RML-2.0
K24 USDM EG
RML-2.0's Avatar
yeah agreed not a huge fan em2's but this one does has some nice mods under the hood.
RML-2.0 is offline   Reply With Quote Quick reply to this message
Old 09-29-2011, 08:39 AM   #14
davidk20ek4
We have a group called k-squad ...
There are alot of us from Washington.... Go check out the k-squad thread in the regional section bud
__________________
Old 09-29-2011, 09:00 AM   #15
aznskaterboy
New Member
Thanks guys! Im not a big fan of the em2 either lol, I just started modding it when I was younger and ended up putting a K in it and now im kinda stuck lol. Might as well make it a beast em2 now...
Ill check it out
__________________
Old 09-29-2011, 09:44 AM   #16
preston
Lifetime Member
preston's Avatar
[QUOTE=aznskaterboy;1437098]Thanks guys! Im not a big fan of the em2 either lol, I just started modding it when I was younger and ended up putting a K in it and now im kinda stuck lol. Might as well make it a beast em2 now...
haha i think that's kinda how we all are now. lord knows i never intended to get this deep in mine. just go with the flow lol
__________________
Vouches:
Old 09-29-2011, 11:45 AM   #17
Axix23
Axix23's Avatar
very sick man... THis is how an em2 should be done up.. Peakboosted!!!!!!!!!! ;)
__________________
:wavey:FORSALE: FS: k20 sparkplug cover, NEW Tial 44mm wg springs(2.9/4.1psi), NEW o2 extension, 06 oem RSX Type S injectors with clips, and NEW Gatorback 4070775 belt.. My forsale thread: http://k20a.org/forum/showthread.php...719#post669719
Axix23 is offline   Reply With Quote Quick reply to this message
Old 09-29-2011, 03:37 PM   #18
aznskaterboy
New Member
yup, just a never ending project that sucks away all my money...
Quote:
Thanks man
__________________
Old 09-29-2011, 03:59 PM   #19
munster
New Member
Quote:
Can't wait. I'm going to have to purchase some slicks. haha.
Is your 35R a .63 hotside or .82?
Old 09-29-2011, 04:43 PM   #20
Scherz Daddy
K20a.org Basic User
Your engine bay looks pretty good man. Nice build.
Scherz Daddy is offline   Reply With Quote Quick reply to this message
Reply
Bookmarks
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
Thread Tools
Posting Rules
You may not post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
