how to k swap honda fit - K20A.org .:. The K Series Source . Honda / Acura K20a k24a Engine Forum
Reply
Thread Tools
Old 09-13-2011, 09:56 PM   #1
breadman
Lifetime Member
breadman's Avatar
Default how to k swap honda fit
ive seen alot of same questions being asked so i thought id start a thread that could be more informative about what needs to be done.
this is an article that will answer most all your questions, anyone looking at doing a k swap fit should read this first
http://www.modified.com/tech/0709_sc...t/viewall.html
there are two sticky at the top of the fit forum section.
i will periodically update this as new info is avilable, anyone that would like to add any tips about there experience doing the swap and things that arent metioned iam sure will help others.
lets keep this free of bumps, non-related material so members dont have to go there 20 pages to find answers.
__________________
http://donkeypowerinjection.com/
www.karcepts.com
http://afhkparts.com/
first k swap fit in north carolina
Quote:
Originally Posted by JMURACN View Post
she either supports the car... or she walks... those are the rules damn it!
breadman is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 09-14-2011, 01:13 PM   #2
t.schultz
K20A.org Sponsor
t.schultz's Avatar
Default Re: how to k swap honda fit
I just had a long conversation with JCrimson, who is currently building a Fit, about mounts. Going by Hasports install guide you will use some of the OEM mounts components. We have the OEM replacements mounts to compensate for the OEM weak mounts. So you can get these along with the Hasport mount kit.
We offer the OEM replacement mounts, Race harness, cables, shifter box, fuel rail (w disconnect), and misc fuel components for that car. I am looking forward to more K-swapped Fit's.
-Tim
__________________
t.schultz is offline   Reply With Quote Quick reply to this message
Old 09-14-2011, 03:39 PM   #3
breadman
Lifetime Member
breadman's Avatar
-Tim
this is very true, when i first did my swap i used the factory mounts and the motor would rock back and forth way to much, my exhaust piping would hit the steering rack and under the car from all the extra movement, i now have 85a mounts which do make for some in cabin vibration but not much, i would atleast recommend no less than 65a, thanks tim
__________________
www.karcepts.com
Old 09-15-2011, 12:41 PM   #4
felixy69
K20a.org Basic User
Thx this is going to be a great thread !
There are few fit (GD) with kswap already in north america in a USDM fit
So there are lots of info that have already been discovered
Feel free to askaway with ur questions !!
I personally have a Auto USDM fit(GD) that I converted with MT k20a with turbo!
I can tell u auto to MT swap in a fit is very difficult..... The entire frame is different so most of the parts made for kswap will not work as they are design only for MT chassis
here was my build thread on fitfreak, which has detailed pics covering alll aspect of the build
http://www.fitfreak.net/forums/fit-p...ld-thread.html
__________________
all item sold as is.
pic are the exact item.
felixy69 is offline   Reply With Quote Quick reply to this message
Old 01-19-2012, 08:04 AM   #5
JCrimson
K20a.org Basic User
JCrimson's Avatar
can someone shed some light on how in the hell am i supposed to enable or wire my electronic power steering? please.
JCrimson is offline   Reply With Quote Quick reply to this message
Old 01-19-2012, 02:55 PM   #6
breadman
Lifetime Member
breadman's Avatar
Quote:
i would contact felix, i have mine done the dbw way so its totally different then yours, he ran into the same problem and had to use either the stock ecu or pcm for that to work, or shoot brian at hasport a email and he would be able to give you some insight on this
__________________
www.karcepts.com
Old 01-20-2012, 05:25 AM   #7
JCrimson
K20a.org Basic User
JCrimson's Avatar
Quote:
I've tried asking Felix, He paid someone to do it all. I asked for atleast some pictures.. waiting.
Old 01-20-2012, 09:08 AM   #8
Tinyvan
K20a.org Basic User
Tinyvan's Avatar
Im not 100% sure but from what I remember my shop telling me they said it sounds like you just plug it in like normal and it should work.
__________________
First K Fit in MN
225whp/180tq
Tinyvan is offline   Reply With Quote Quick reply to this message
Old 01-20-2012, 09:30 AM   #9
JCrimson
K20a.org Basic User
JCrimson's Avatar
Quote:
hmmm, well i didnt unplug any of it, I really have no clue what powers it thought.
Old 01-20-2012, 10:37 AM   #10
Tinyvan
K20a.org Basic User
Tinyvan's Avatar
Im in the same boat as Felix as I had a shop do my swap as well. I dont know this set up as well as you do, but I did go take some pics, at least the best I could. Its just a single harness that comes off the unit then goes up the firewall. I fallowed it the best I could but I lose it behind the brake booster and driver side shock tower. Hope these pics help you a little bit.
^the big harness goes up behind the driver side tower, the smaller offshoot goes to the battery and fuse box
__________________
First K Fit in MN
225whp/180tq
Old 01-20-2012, 11:15 AM   #11
JCrimson
K20a.org Basic User
JCrimson's Avatar
hey thanks man! Im on the same page with you too. I have it all plugged up oem but somewhere someone mentioned you have to jump the signal from the L15A ecu to power it on and control it...
are you using 1 ecu or 2? I am just using kPRo.. if you are just using 1 ecu, then there is a way they did it for you and thats what i really what to know. Mine is all plugged up but something is not telling it to turn on like it should.
Old 01-20-2012, 11:20 AM   #12
Tinyvan
K20a.org Basic User
Tinyvan's Avatar
I believe im just using the haltech ecu
__________________
First K Fit in MN
225whp/180tq
Old 01-20-2012, 11:24 AM   #13
JCrimson
K20a.org Basic User
JCrimson's Avatar
hmmm, i will double check all connections this weekend.
Old 01-05-2017, 04:43 AM   #14
fightinghamster
New Member
I am currently piecing together my swap and was hoping to have some questions answered ive been in contact with hasport but I need to know if the stock fit clutch lines will bolt to the k20z3 motor/tranny and where to get parts that hasport dosent supply I know hybrid racing has some parts but im not sure what I need and info helps
fightinghamster is offline   Reply With Quote Quick reply to this message
Reply
Bookmarks
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
Thread Tools
Posting Rules
You may not post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
