k20a base?? vs k20a type r ?? - K20A.org .:. The K Series Source . Honda / Acura K20a k24a Engine Forum
Reply
Thread Tools
Old 03-30-2011, 10:39 AM   #1
peroyblanco
New Member
Default k20a base?? vs k20a type r ??
came across a stamped k20a(not an a3 z3 z1 ect) with a plastic mani,guy said it he picked it up in japan when he was over there,does anyone car to explain... im looking for specs aswell if anyone can help out,thanks
peroyblanco is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 03-30-2011, 10:44 AM   #2
joescivic
K20a.org Advanced User
Default Re: k20a base?? vs k20a type r ??
Quote:
Originally Posted by peroyblanco View Post
came across a stamped k20a with a plastic mani,guy said it he picked it up in japan when he was over there,does anyone car to explain... im looking for specs aswell if anyone can help out,thanks
you're going to have an "a" after "k20" on some of the motors. for some reason, even people with k20a2's or k20a3's call it a k20a motor. k20a is JDM. like other series motors that are JDM, there is no number after the first 3 digits. so the k20a is the type-r. if its a 2.0L with a black intake manifold, its probably the k20a3 from the base model RSX. but, coming from Japan (if he really picked it up there) then i dont know what it might be. you should check the stamp on the block to confirm what it is
joescivic is offline   Reply With Quote Quick reply to this message
Old 03-30-2011, 10:53 AM   #3
peroyblanco
New Member
Quote:
what i am saying is it came from japan with a plastic mani.and i said its stamped k20a on the block.what my question is in what car did this come in and what are the specs as far as compr/hp/tq/vtec ect..
on wiki it shows that there is one k20 with 180hp with low comp but doesnt say what car or ther type of info
Old 03-30-2011, 10:56 AM   #4
Bossman
Lifetime Member
Bossman's Avatar
I believe the euro FN2 CTR has a plastic intake mani....and it would also be labeled K20A
__________________
Quote:
Originally Posted by pulpmelon_r View Post
Why are you lol'ing?
You cannot mock some one for being fearful of an oppressive government when you are afraid of walking the streets with legal firearms around.
Quote:
Originally Posted by signalpuke View Post
I can't be the bad guy if you are the bad guy. Two bad guys is too many bad guys. :P
Bossman is offline   Reply With Quote Quick reply to this message
Old 03-30-2011, 11:18 AM   #5
signalpuke
Keep walking...
signalpuke's Avatar
Get a picture of the tag on it. Should be a white tag with a barcode and some letters and numbers on it
__________________
New to the K-Series? ☆★☆★ DIY and FAQ ★☆★☆ <------- CLICK THE LINK!
Otatsiihtaissiiststakio piksi makamo ta psswia
signalpuke is offline   Reply With Quote Quick reply to this message
Old 03-30-2011, 11:21 AM   #6
K20a EJ1
New Member
I had the same motor. Its a JDM k20a out of a Integra Type S. The motor doesnt have true vtec like the k20a3, but does produce more power than the k20a3. There are two different engines of the integra type s the one made in 2002-2004 makes 182hp and 145lb Ft. If you have the 2005-2006 engine it makes 210hp and 141lb ft. If you wanna keep it just lock the rockers with some a2 cams and it will make decent power.
K20a EJ1 is offline   Reply With Quote Quick reply to this message
Old 03-30-2011, 11:25 AM   #7
peroyblanco
New Member
i should of but i forgot next time i go illget one
Quote:
oooo this is what i was looking for,thanks
Old 03-30-2011, 11:27 AM   #8
signalpuke
Keep walking...
signalpuke's Avatar
Black plastic intake manifold. Black lettering on the valve cover shield (says 2.0 iVTEC or somthing in black)?
__________________
Old 03-30-2011, 11:30 AM   #9
peroyblanco
New Member
didnt have a shield just the mani
Old 02-25-2012, 05:49 AM   #10
Gurule92
New Member
I have the same situation did you ever figure out what this was?? mine has
Black plastic intake manifold. Black lettering on the valve cover shield (says 2.0 iVTEC in black i have a picture of the sticker here.. so far everyone says its base model, but i am just looking for hope lol http://forums.clubrsx.com/showthread...8#post39087888
Gurule92 is offline   Reply With Quote Quick reply to this message
Old 02-25-2012, 05:58 AM   #11
signalpuke
Keep walking...
signalpuke's Avatar
It is a base model.
__________________
Old 02-25-2012, 08:30 AM   #12
K20a EJ1
New Member
It's not a base us motor I don't know why people keep saying. Read my post before and I have numbers and explain what car it's out of.
Old 02-25-2012, 08:48 AM   #13
signalpuke
Keep walking...
signalpuke's Avatar
Does it have three lobe cams on both the intake and exhaust?
__________________
Old 02-25-2012, 09:25 AM   #14
_Mozz_
K20a.org Master User
Quote:
Euro FN2 Doesnt have a Plastic intake manifold, it has the (awsome) RSP mani... And its labeled K20Z4.
__________________
- FN2 - Ultimate Street Stroker Build -
http://www.k20a.org/forum/showthread.php?t=99260
_Mozz_ is offline   Reply With Quote Quick reply to this message
Old 02-25-2012, 02:26 PM   #15
Gurule92
New Member
yours or mine?
Old 07-08-2014, 08:47 PM   #16
Dirty92eg
New Member
Came out of a base 02-04 or 04-06 Japanese honda dc5 or something like that. Or an si civic also from Japan. I have the same motor in my driveway
Dirty92eg is offline   Reply With Quote Quick reply to this message
Old 07-09-2014, 03:40 AM   #17
screech
duct tape and zip ties
screech's Avatar
Quote:
GIFSoup
__________________
DIY | FAQ
stock is gay, like blowing richard simmons in a porta potty at a elton john concert.
"I am absolutely amazed sometimes by how much thought goes into doing things wrong"
screech is offline   Reply With Quote Quick reply to this message
Reply
Bookmarks
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
Thread Tools
Posting Rules
You may not post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
