K24a2 head or K20a2 head on K24a1 Block?? - K20A.org .:. The K Series Source . Honda / Acura K20a k24a Engine Forum
Reply
Thread Tools
Old 03-21-2011, 09:30 PM   #1
filipinop1405
K20a.org Basic User
filipinop1405's Avatar
Location: Fayetteville/Fort Bragg, NC; Currently Recruiting in Tulsa, OK
Default K24a2 head or K20a2 head on K24a1 Block??
My main question is whether or not the TSX(k24a2) head will just bolt up to a CRV(k24a1) block and work? any modifications? I plan to use either an RBC IM or RRC IM along with kpro with this. I just want to make sure that there isn't anything extra that I need or need to do before I start looking for one (while I save up money for it).
If I found a bare TSX head,with it being similar to the K20a2 head, would the k20a2 valve train work in it (TSX head).
I've searched the following but didn't see anything....
diy|faq ☆★☆★☆★☆★ diy|faq ★☆★☆★☆★☆ diy|faq
k24 block with k20a2 head It's talking about the TSX motor not the CRV motor.
Thanks!!
filipinop1405 is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 03-21-2011, 09:32 PM   #2
1320WhtRex
K20a.org Bounty Hunter
1320WhtRex's Avatar
Default Re: K24a2 head or K20a2 head on K24a1 Block??
Yes it will work just fine. You can use it. If you're getting the head for a pretty good price, go for it..
__________________
IF YOUR FS THREAD IS
NOT IN COMPLIANCE WITH THE RULES IN THE LINK BELOW, I WILL LOCK AND/OR DELETE THE THREAD WITHOUT NOTIFICATION. THANKS
FOR SALE RULES
10.1@148
Quote:
Originally Posted by Murrdog9000 View Post
...K series turbo.... not for the cheap
Vouches and Feedback Thread ,
My EF Kswap Turbo Build Thread
R.I.P. Jose Rodriguez, Robert Mercado Jr.... We'll miss you forever... Gone but not forgotten
1320WhtRex is offline   Reply With Quote Quick reply to this message
Old 03-22-2011, 07:05 AM   #3
filipinop1405
K20a.org Basic User
Quote:
So there isnt any modifications that needs to be done? No ports that have to be welded? What about the IM RBC and RRC, any mods that I would have to do to them to get them to fit? Thanks for your response!
Old 01-16-2012, 03:17 PM   #4
CTR*mAr
K20a.org Basic User
Bump I am also curious if their is less to do if your puttin a k24a2 he's on a k24a1 rather then a k20
CTR*mAr is offline   Reply With Quote Quick reply to this message
Old 01-16-2012, 03:18 PM   #5
CTR*mAr
K20a.org Basic User
Head ^^*
Old 01-18-2012, 12:05 AM   #6
vtecjj
New Member
Quote:
No, the rbc and rrc will bold DIRECTLY onto the K24a2 head. No modifications at all. IF you were to use the K20a2 head, you would then need to cut off the water port on the rbc and/or rrc.
On one of my race engines, I have a K24a2 head with a RRC manifold-straight bolt on.
__________________
Check out: www.facebook.com/merismotorsports for race reports and featured products
JMeris: NASA HPD 2011 Honda Challenge H1 National Champion, NASA HPD 2010 Honda Challenge H2 National Champion------Honda Challenge's 1st Back-to-Back, 2-class National Champion
vtecjj is offline   Reply With Quote Quick reply to this message
Old 02-13-2012, 05:56 AM   #7
HMOOB
New Member
HMOOB's Avatar
i have a question to add to this. are there any compression differences when using a k20a2 head on a k24 block rather than the k24a2 head on a k24 block? reason is because i saw some pistons made specifically for a k24 and some for k20/k24 engine.
HMOOB is offline   Reply With Quote Quick reply to this message
Old 02-13-2012, 06:24 AM   #8
signalpuke
Keep walking...
signalpuke's Avatar
The head cc will be very close to the same size.
The K20 pistons are spec'd for the 86mm crank, and require a much larger dome to attain the higher compression ratio.
So, if you put 88mm K20 12.5:1 pistons in a K24, it would shoot the compression up towards 14:1. Understand?
__________________
New to the K-Series? ☆★☆★ DIY and FAQ ★☆★☆ <------- CLICK THE LINK!
Otatsiihtaissiiststakio piksi makamo ta psswia
signalpuke is offline   Reply With Quote Quick reply to this message
Old 02-15-2012, 05:12 PM   #9
HMOOB
New Member
HMOOB's Avatar
what if for example: wiseco have a set of 11.1 pistons for a k24 and i wanna use that on a k20/k24 build, will the compression go down since ill be using a k20 head instead of a full k24 or will it only go down if i use on a full k20 engine? thats where im lost.
Old 12-24-2013, 10:11 AM   #10
10dsbrennan
K20a.org Basic User
10dsbrennan's Avatar
I recently bought a k24a2 head complete off of eBay for a very good price. I am in touch with King Motorsports on this build and Mike informed me that my K24a2 head is crap compared to the K20a2 in terms of flow.
My question is, with the price I paid for the TSX head-- extremely cheap-- is it even worth it for me to go over to a complete type-s head and have that inspected and have imperfections all machined out? I'm aiming for 250 whp for a reliable daily.
10dsbrennan is offline   Reply With Quote Quick reply to this message
Old 12-24-2013, 10:15 AM   #11
brakaT
K20a.org Master User
brakaT's Avatar
If you want to use the TSX head, hit up 4 piston for their PRO TSX CNC head, perfect for street motors
In stock form, the TSX head is a waste of time and the K20A2/K20Z1/K20Z3 head will be a lot more beneficial.
What are the rest of your motor specs?
__________________
2000 CW JDM RHD ITRx
Neighbourhood Troll
brakaT is offline   Reply With Quote Quick reply to this message
Old 12-24-2013, 10:19 AM   #12
10dsbrennan
K20a.org Basic User
For now, K24a1 block, K24a1 crank, and K24a2 head. That's it. I bought the head because it had real VTEC and because it was cheap. My next step was going to be getting the block/head/crank inspected and machined.
Old 12-24-2013, 03:54 PM   #13
signalpuke
Keep walking...
signalpuke's Avatar
You can hit 250whp no problem, use what you have and spend that money on other stuff like cams.
__________________
Old 12-24-2013, 04:04 PM   #14
10dsbrennan
K20a.org Basic User
Yeah, that's what I was thinking. If I can save a couple extra pennies by keeping the k24a2 head that'd be good.
Old 12-26-2013, 08:21 AM   #15
AWH
K20a.org Advanced User
For a simple build, "crap" is an exaggeration.
Here's a good thread about the difference between the best OE head (RSP) and the K24A2 head. First page has a dyno compare. A K20A2 is somewhere in between (closer to the RSP).
http://www.k20a.org/forum/showthread.php?t=107797
And if you look through the stickied DIY FAQ, you'll find a nice flow chart that Luke @ 4Piston ("Drag") put up with all the OE heads.
__________________
Track/AutoX: 89 CRX K24, New track build ==> K-swapped NB Miata
AWH is offline   Reply With Quote Quick reply to this message
Old 12-29-2013, 09:39 AM   #16
10dsbrennan
K20a.org Basic User
I think I'm going to pull the trigger one next paycheck
__________________
Old 01-09-2014, 07:47 PM   #17
10dsbrennan
K20a.org Basic User
Anybody know how long they'll be holding my head at JFK International?
It's shipping from Canada...any experience with international shipments?
I'm pretty sure they do customs there....it's been on hold for a couple of days.
__________________
Old 01-19-2014, 06:21 AM   #18
johnkilo
K20a.org Basic User
johnkilo's Avatar
I'm assuming you've gotten it by now, but I had a laptop shipped to me from Vancouver (I'm in Connecticut) and customs had it for over a week.
__________________
Real Hondas
johnkilo is offline   Reply With Quote Quick reply to this message
Old 01-19-2014, 07:13 AM   #19
10dsbrennan
K20a.org Basic User
Yeah bro i got it. they bent a damn stud on my head though!!! >
its all good though...its a 3 dollar replacement from Honda to fix it.
__________________
Old 05-31-2016, 03:45 PM   #20
1year2many
New Member
1year2many's Avatar
So the k24a2 head will fit on with no modification to my k24a1 crv, however I should get an aftermarket one instead of one used in a tsx? Also does anyone know for sure that the rsx type s oil pump will bolt on with no mods as well? I've heard it will but haven't read anything confirming it
1year2many is offline   Reply With Quote Quick reply to this message
Reply
Bookmarks
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
Thread Tools
Posting Rules
You may not post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
