I wondered if anyone else is having similar TPS issues.I have been having an ongoing issue with TPS sensors(any brand) failing on me in my K20R powered race car and I want to get to the bottom of it and fix it, or find a way to use a different TPS with a fabricated adapter.
I thought I may have a wiring issue,so I basically replaced every harness on the car with a brand new one.I realized that was not it after the failures continued.I thought it may be the brand of sensor.That came to no result either.So the last few sensors, I opened it up to discover the problem,small internal wire gauge breaking/failing.Is it vibration,maybe heat?
I know for sure it is not my wiring,each harness(chassis,swap,engine) and ground has been replaced and tested and the used ones are just as equal as the Brand new harnesses in performance.Sensors still fail.
In the pictures
The Left pic note the "aftermaket Omni brand" K series TPS: It has very tiny wire size that seems far too fragile to be on a vehicle.
Note on right the OEM K series Keihin TPS: Large wire like B series and durable.The Keihin downfall is the ceramic board sometimes breaks on them and I cant find one without buying a whole TB.Anyone have one
Since I am using aftermaket all the time,This is what is breaking on my sensors consistantly.The car runs awesome,then randomly shuts off and goes into limp mode 20mph or 2000rpm.I replace the sensor,recal the Kpro and the car runs again till the sensor randomly fails the next time.
In the pictures
